David P Posted May 22, 2017 Share Posted May 22, 2017 When buying a "complete transmission", if it's not complete with cross-member, nut's, bolts, washers, oil-lines and donut etc sufficient for your requirement, haggle the price down hard. Pay attention to these little things, because you could easily end up paying more for nuts & bolts than you did for the transmission! These 'insignificant' ( "Easy fix mate" ) components are difficult to source used and new ones add up to arms and legs. For reference, here's a list of all these little bits & pieces, with part no.s and prices too when they come my way. The waaaaay out of date Toyodiy $ prices are there to give you a clue. Should you have information of any recent prices in £ GBP, please don't be too complacent to let me know and I can then update the price & credit. Thank you. Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 SPACER, DRIVE PLATE, FRONT 32116-22020 1 $29.18 SPACER, DRIVE PLATE, REAR 32117-22020 1 $14.98 Flex-plate to crank bolt 90105-10294 *10-1.25PX22-15 x 8 (When using used, ensure there's a number "11" on the head) $1.34 Flex-plate to torque converter bolt 90105-10340 *10-1.5PX12.8-9.8 x 6 (When using used, ensure there's a number "11" on the head) £1.00 + VAT. Delboy52 Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 Bell-housing to engine bolt 91619-61250 *** STD. PART x 5 $2.85 90119-10260 *** STD. PART x 4 $3.12 Starter motor to bell-housing bolt 90119-10180 *** STD. PART x 2 $2.41 Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 Bell-housing to transmission bolt 90119-10232 *** STD. PART x 4 $1.50 90119-12036 *** STD. PART x 2 $2.10 CROSS-MEMBER SUB-ASSY, ENGINE REAR MOUNTING 57255-14230 (05/1993 - 04/1995) $250.74 57255-14231 (05/1995 - ) $239.44 Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 Cross-member to chassis bolt 90119-10551 *** STD. PART x 4 $2.06 Rubber mount - transmission to cross-member. INSULATOR, ENGINE MOUNTING, REAR NO.1 12371-46120 $92.60 Cross-member to rubber mount nuts x 4 90179-08159 *** STD. PART $1.27 Transmission flange to prop NUT 90179-11017 x 4 £2.66 + VAT. bluesonic94 WASHER, NO.2 (FOR PROPELLER SHAFT) 90201-11013 x 4 £0.90 + VAT. bluesonic94 Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 BOLTS, NO.1 (FOR CENTRE SUPPORT BEARING) 90119-10217 40 x 2 $2.10 WASHERS, NO.2 (SPACERS FOR CENTRE SUPPORT BEARING) 90201-10123 2.0 x 2 (matched to shell) $1.38 90201-10125 4.0 x 2 (matched to shell) $2.02 90201-10127 6.0 x 2 (matched to shell)$2.33 90201-10128 8.5 x 2 (matched to shell) $4.15 Link to comment Share on other sites More sharing options...
David P Posted May 25, 2017 Author Share Posted May 25, 2017 Prop to Diff COUPLING, FLEXIBLE (Size "B" Donut) 37511-30020 $354.17 BOLTS (FOR FLEXIBLE COUPLING) 90105-12265 *12X1.25PX59.5-20 x 3 $10.83 NUTS (FOR FLEXIBLE COUPLING) 90179-12128 x 3 $1.38 WASHERS, PLATES (FOR FLEXIBLE COUPLING) 90560-12059 x 3 $5.89 Link to comment Share on other sites More sharing options...
