David P Posted October 12, 2017 Author Share Posted October 12, 2017 GTE accumulator + GE springs = P-to-D bump GTE accumulator + GTE springs + modified GTE cap = No bump, but also no Reverse GE accumulator + GE springs + modified GTE cap = P-to-R bump GE accumulator + GE springs = P-to-D bump, but less so GE accumulator + GE springs + 1 washer shim = Best combo so far GE accumulator + GE springs + 2 washer shim = ? Or, have a go & let us know? Link to comment Share on other sites More sharing options...
David P Posted November 11, 2017 Author Share Posted November 11, 2017 I am working my way through the possible C-0 accumulator combinations, trying to result with a Hybrid transmission that engages D like a stock box, yet in the meanwhile, I remind you that all you need to do for a bump-less engagement is............. Pause in R before engaging D Link to comment Share on other sites More sharing options...
David P Posted November 11, 2017 Author Share Posted November 11, 2017 My spine is giving me some pro per gip at the mo and I''m not up to very much at this time. Consequently, I have given J some more tuition, lent him some of my tools and he is going to have a go at dropping the V.B. himself and swap back to the best known C-0 accumulator combo of; GE accumulator + GE springs. He has watched and helped me do this job four times now, on three of these occasions working from underneath. He has also on two occasions helped me to split and rebuild a valve body and I'm confident that he is up to the job. It looks like I have an apprentice. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2018 Author Share Posted March 15, 2018 I don't know why, but in some N/A boxes it is not possible to get a cable tie in the gap shown as on previous page? Alternatively and faaar better, is to fit a tag to this bolt and then you can use stronger cable ties. Getting to this bolt can only be done with the valve-body removed. Link to comment Share on other sites More sharing options...
David P Posted June 4, 2019 Author Share Posted June 4, 2019 With a bit of luck, on Saturday; for the interest of "Science" both Zedhex Patrick & Delboy52 Mike, will bring their cars to mine and we will then have the opportunity to compare these 2 variations and discover if shimming the C-0 is an improvement or not? GE accumulator + GE springs = P to D bump, but less so (Best combo so far - trying to better) (Delboy52) GE accumulator + GE springs + 1 washer shim = ? (Zedhex) Link to comment Share on other sites More sharing options...
David P Posted June 8, 2019 Author Share Posted June 8, 2019 Mike and Patrick have had their Bump-Off and found that the addition of a shim to the C-0 accumulator is an improvement. Next will try 2-washers? Link to comment Share on other sites More sharing options...
David P Posted August 17, 2019 Author Share Posted August 17, 2019 I have built Sam Weller a Hybrid incorporating a 2-washer shim in the C-0 accumulator. After it is fitted he will be bringing me back some donor transmission components that I loaned to him, then we can have another Bump-Off. Link to comment Share on other sites More sharing options...
