Line-Pressure Feed-Cable
It is VERY IMPORTANT that this cable functions as designed.
I have seen Hybrid installations where this cable has been ignored completely, this results with the pressure being too low to grip the clutches and consequently, burn out.
I have also seen installations where this cable is locked open at full pressure, this results with aggressive and damaging jumping when engaging D and lots of wheel-spin off the line.
It's not rocket science, it's a cable!
With an N/A auto throttle body it is plug & play, if using a T.T. inlet manifold, use a Soarer 1J-GTE throttle body which has the correct cable ramp and also plug & play.
Swapping engines, swapping transmissions and/or polishing or painting throttle-bodies entails removal of the cables from the throttle-body which leads to a reassembly mistake that I have come across several times.
The favourite mistake is to forget the lower/left ramp and to fit throttle and line-pressure cables onto the right/top two positions.
On Supra N/A auto & Soarer 1J-GTE throttle-bodies there are 3 cable ramps.
Left - Transmission line-pressure.
Centre - Throttle.
Right - Cruise-control.
Reassembly in an incorrect configuration causes several different combinations of malfunctions which could render the car unsafe to drive or/and destroy the transmission.
Stock N/A auto throttle body cable ramps. Left, line feed cable - Centre, throttle cable - Right, cruise-control.
(Soarer 1JZ-GTE T.B. locates the cables in same positions.)
Should your t.b not have a ramp for this cable, alternatively, using nipple and trans mount from original cable & bicycle cable-components it can be connected directly to the accelerator pedal
Supra acc pedal has a use-able hole 20mm below stock cable mount :)
Hole drilled in bulkhead 20mm below stock-cable & new-cable fitted (18mm would be a better match with throttle cable mount bracket inside) :think:
A little fettering with a Dremmel, this extra cable then cleared the bracket
Using rubber-stopper from GE throttle-cable, a washer & terminal block-connector, job done:thumbs:
  • 2 years later...
At the pedal-end of the cable-core, run-solder along it, from where the cable-block will cramp onto it, to where you plan to cut it. :think:
Do this before you cut it, the cable will then not deform under the screws and your end will never fray. :amen:
By feel, at zero pedal-depression, set the cable to; "only just not doing anything" and the big squidgy N/A throttle-cable rubber-stopper (or similar), will allow for any slight difference there might be in the two-cables travels at WOT? :thumbs:
Confirm that accelerator-pedal has full-travel without putting strain on the line-feed cable, :think: you really don't want the job of finding and re-soldering the nipple back on at the other end. :shrug:
