Transmission Fluid Coolers
Transmission fluid coolers are the simplest way to upgrade an automatic transmission.
Heat kills automatic transmissions, torque creates heat.
The more efficient the fluid temperature, the more torque an automatic transmission will take.
An essential yet simple upgrade before fitting a single turbo. :)
Thank you. :)
I like tea strong, with only a dash of milk and no sugar please.
Transmission fluid is like Baby Bear's porridge, it needs to be; not too hot and not too cold.
An additional oil cooler prevents the ATF from becoming too hot and a Mocal oil thermostat prevents it from being too cold.
Simples!
