How-To I.D. Supra "Family" Automatic Transmissions *****
:thumbs: The Definitive - Which Auto Box Is What :thumbs:
:think: Identifying Supra automatic transmissions .......... is not as simple as one(s) might think. :confused:
:smartass: Below are details of their external little differences. :slap:
Mr T. doesn't help by titling Supra N/A & T.T. Automatic Transmissions both; "A340E" :confused:
  • 2 years later...
XXXXXXXXXXXXXXXXXattachment.php?attachmentid=219110&d=1495897122
Aisin AW - alternative & multi-purposed plate-codes - add to the mystery :confused:
For I.D. Mr T originally used yet another set of code numbers on a "fade or fall-off" bar-code sticker & :zzz: omitted to mention the Aisin AW numbers in his Bible(s)? :confused:
Mr T now uses vehicle registration numbers and attachment.php?attachmentid=209825&d=1457191025 computer magic. attachment.php?attachmentid=209841&thumb=1&d=1457258044
Tip: Despite many matching numbers - you need to confirm it has matching flange & socket :slap:
Supra J spec 2JZ-GTE A340E: 30-40LE 35000 1B310 93J R 00754 :hi: Chris Wilson
XXXXXXXXXXXXXXXXXXXXXX..30-40LE 35000 1B310 93D R 10093 :hi: Shane
Supra UK spec 2JZ-GTE A343E: 30-43LE 35000 1B330 93E R 05636 :hi: bluesonic94
XXXXXXXXXXXXXXXXXXXXXXXX.30-43LE 35000 1B330 94D R 05764
Aristo A340E: 30-40LE 35000 3A680 94D R 06097
XXXXXXXXXXX30-40LE 35000 3A680 93D R 21873
Soarer 1JZ-GTE A340E: XXXXX30-40LE 35000 24320 95C R 04942
Soarer 1JZ-GTE VVT-i A341E: 30-41LE 35000 2C220 96K E 00046
Soarer 1UZ-FE A341E: XXXXX 30-41LE 35000 24240 92D E 05899 :hi: J_Meiser
LS400 1UZ-FE A342E: XXXXX 30-42LE 35000 50091 95K E 10460
1st Gen GS300 A343E: XXXX. 30-43LE 35000 3A871 94C E 01180 :hi: J_Meiser
External Descriptions of Supra 'Family' Auto Transmissions
Supra GE - J1 bell-housing, line-pressure feed-cable, splined tail-shaft, 3-pin solenoid-socket & 'straight' cross-member
Supra GTE - J & UK spec - J3 bell-housing, 4-stud prop-flange, 8-pin solenoid-socket and 'boomerang' cross-member
Supra GTE VVT-i Tiptronic - looks same as GTE Auto, yet has 12-pin solenoid-socket
30-40LE with 3-pin solenoid socket; is one of my Hybrids :baby:
Aristo Auto & Tiptronic - same as Supra TT, yet has size 'B' 3-hole prop-flange
A343E UK spec Supra & (Lexus 1st Gen GS300) J3 bell-housing (GS300 J2) & 4-stud prop-flange (GS300 size 'A' 3-hole)
A340E 1JZ- GTE Soarer - externally same as Supra GE yet internally has different valve-body & more clutches (plate id 24320)
A650E (5-speed) - 12-pin solenoid socket - size 'B' 3-hole prop-flange
1UZ-FE non VVT-i variants have U1 bell-housing, breather pipe & size 'A' 3-hole prop-flange
Photographs of Transmissions
Top: Supra T.T. A340E-GTE 30-40LE - J3 bell-housing - 4-stud flange - 8-pin solenoid socket
Bottom: Supra N/A A340E-GE 30-40LE - J1 bell-housing - line-feed cable - sliding-yoke - 3-pin solenoid socket
Note different solenoid sockets :think: Also note Mr T's original fading and/or falling off Bar-Code stickers :confused:
30-40LE - J3 bell-housing - line-feed cable - 4-stud flange - 3-pin solenoid socket; is one of my Hybrids. :baby:
H1. This one is mine. :love:
Aristo Auto A340E 30-40LE & Tiptronic A34#E 30-40LS boxes look same as Supra TT, except for Aristo having 3-hole size 'B' donut prop-flange & the Tipronic having a 12 pin solenoid socket.
With some having a :love: sexy dipstick handle.
Note: 8-pin solenoid socket indicates this 3-hole flange Aristo box is an automatic :think:
1UZ-FE VVT-i A650 has U1 bell-housing, breather pipe and size "B" 3-hole prop-flange
(pic :hi: Delboy52 )
Note: V8 starter-motor bulge is at top of bell-housing :think:
Cross-members
The 'boomerang' shaped one at the top part no. 57255-14231 and/or 57255-14231, allows for the additional 18mm length of J3 & U2 bell-housings.
The 'straight' one at bottom, part no. 57255-24060 and/or 57255-24061, pairs with J1 bell-housing on Supra GE & Soarer GTE.
After more than one complete sample sets of code numbers have been collated it will be possible to identify a transmission with them? :confused:
The secrets are hidden in this group of the code?
30-40LE 35000 1B240 95E R 00095
Until then, I have explained how to see them in the Real World, without the need for spectacles. :shrug:
Should I have made any error, or should you have a missing complete plate-code to donate, please contact me and I will edit.
Should you have further information to add, please feel free to do so. :)
:hi: Thank you
Sample code: 30-40LE 35000 1B240 95E R 00095
30 = Transmission model
4 = Number of forward gears
0 = Model number
L = Lock-up torque-converter
E = Electronic (S = Tiptronic)
35000 = Transmission series
1B = Supra JZA80
240 = GE (310 = GTE) (360 = GTE VVT-i)
95 = Last 2 digits of Manufacturing year
E = May - Month (A to M, “I” not used)
R = A340E or A340F (F = Transfer-case)
00095 = 5-digit serial number
The Aisin AW plates are now decoded enough to identify Supra transmissions. :)
For the records, I'll continue to compile the remaining transmission pics & plate-codes, if you have access to either, please don't be shy.
:hi: Thank you.
  • 5 months later...
  • 3 months later...
Despite my considerable yet apparently totally and completely unappreciated efforts to help members ID these boxes, I constantly receive Prisoner Messages with further questions, because of the missing information that I still seek!
This information is in the possession of members who are too F lazy and/or too F ignorant to volunteer this for the benefit of other members.
Ironically, the person's who want-want WANT information, are mostly the same person's who won't-won't WON'T give information! :shrug:
I have been trying to fill in these final little gaps in the AisinAW code plates information for 3-years now. :looney:
If you can provide any of these final & definitive pieces of information, please do?
Thank you.
  • 8 months later...
  • 1 year later...
