Oil feed restrictor - do we use them?
Rich.2211
Having mixed reviews about the oil feed for .70AR journal bearing turbo. Do you need a restrictor so you dont blow the seals? Im going to run AN4 fittings/line. After some research a few people say AN4 is quite restrictive already although others say you need a 1.5mm hole in the flange. Opinions please :) want to get it right the first time!
