What's it all about?
N/A-T with stock GE single-coil ignition works fine up to a point where closing the plug gap (reducing the efficiency of the spark) will no longer prevent boost blowing out the spark.
The more efficient TT multi coil-packs ignition system(s) cures this and it's such a cheap, simple and better way of doing it in the first place, why not?
Why do you think Mr T. put coil-packs on turbo'd J's and later upgraded the GE in VVTI form with coil-packs?
The 3 coil VVTI system is more efficient than the earlier 6 coil system, which also conveniently fits nicely under the N/A induction and can be used with a TT ECU on N/A.
There's no longer a distributor and/or cap to get in the way of the turbo plumbing and it looks cool too.
Ignition upgrade = Win
Can run more boost =Win
Space for turbo & induction = Win
Easily sourced OE components = Win
Cheap used components = Win
Easy to do = Win
Mostly plug & play = Win
Looks cool = Win
