David P Posted February 8, 2014 Share Posted February 8, 2014 Follow the link to a new Club Group; "2JZA80-GE & Coil-Packs". http://www.mkivsupra.net/vbb/group.php?groupid=62 Link to comment Share on other sites More sharing options...
steve spedd Posted February 9, 2014 Share Posted February 9, 2014 This sounds really interesting!! But I can't get the link to work David. Link to comment Share on other sites More sharing options...
David P Posted February 9, 2014 Author Share Posted February 9, 2014 The link is repaired. Link to comment Share on other sites More sharing options...
steve spedd Posted February 9, 2014 Share Posted February 9, 2014 Thanks David. Do I need the Tt ecu of will the emanage blue with the NA be ok? I'm NA-t. Many thanks. Steve Link to comment Share on other sites More sharing options...
Guest Fly Posted February 10, 2014 Share Posted February 10, 2014 Nice one David Link to comment Share on other sites More sharing options...
David P Posted February 12, 2014 Author Share Posted February 12, 2014 EMU or other piggybacks with NA ECU works fine up to a point where closing the plug gap (reducing the efficiency of the spark) will no longer prevent boost blowing out the spark. The more efficient TT coil-packs ignition system cures this and it's such a cheap, simple and better way of doing it in the first place, why not? Why do you think Mr T. put coil-packs on turbo'd J's and later upgraded the GE in VVTI form with coil-packs? The 3 coil VVTI system is more efficient than the earlier 6 coil system, which also conveniently fit nicely under the N/A induction and can be used with TT ECU. No distributor to get in the way of the turbo plumbing and it looks cool too. Ignition upgrade = Win Can run more boost =Win Space for turbo & induction = Win Easily sourced OE components = Win Cheap used components = Win Easy to do = Win Mostly plug & play = Win Looks cool = Win Link to comment Share on other sites More sharing options...
David P Posted June 15, 2014 Author Share Posted June 15, 2014 Steve, Not sure re. the Emanage blue & N/A ECU, yet if not, use a T.T. ECU with the Emanage and Bobs your Uncle. Link to comment Share on other sites More sharing options...
David P Posted June 15, 2014 Author Share Posted June 15, 2014 Steve, Not sure re. the Emanage blue & N/A ECU, yet if not, use a T.T. ECU with the Emanage and Bobs your Uncle. Join the coil-pack group and ask your questions there, then the answers are easier for others to find. Link to comment Share on other sites More sharing options...
