O2 Sensors
Guest d-_-b
Thanks for putting this up. I would like to add that for any potential na-t the problem of either having to weld the old O2 sensors to the downpipe or buy new ones that screw in is a problem. However if you are purchasing a wb02 sensor and gauge, some now feature a simulated narrowband output that can be spliced into the existing O2 sensor wiring to fool the ecu ( assuming you are running piggy back) this then means you can run a single wideband sensor in your down pipe. The innovate MTX-L afr gauge and sensor has the function and is a great bit of kit.
  • 2 weeks later...
I will add to my last that the MTX-L gauge has 2 outputs. 1x simulated narrowband to replace your stock o2 sensors and 1x WB output which if you run EMU can be connected to one of the option ports to feed the EMU A/F target MAPS.
I will be running this setup and will fire up some piccies when the install is complete.
