jumper settings for the greddy e-manage ultamate
ballsdeep
here is how your jumper settings should be set in the greddy ultamate EMU.
open up your emu by undoing the alen key screws in the front then pull out the emu from its housing.
here is a picture i took from my booklet:
* when jumping "1-2" or "3-4" make sure to match the pin numbers printed on the circuit board at the coresponding jumper locations. For "OPEN" make sure the jumper is not jumping the pins at the corresponding jumper locations. its real easy to do.
and this is how the jumpers should be set for the 2jz-ge ( if you have bought the EMU brand new then it will most likely already be set this way but still check it over first, if you have bought the unit second hand/used it could have been changed especially if its been fitted to a different make and model of vehicle).
Jp - 1 - open
jp - 2 - open
jp - 3 - open
jp - 4 - open
jp - 5 - open
jp - 6 - open
jp - 7 - 1-2
jp - 8 - 1-2
jp - 9 - open
jp - 10 - 1-2
jp - 11 - open
jp - 12 - open
jp - 13 - open
jp - 14 - open
jp - 15 - 1-2
jp - 16 - open
jp - 17 - 1-2
jp - 18 - open
jp - 19 - 1-2
jp - 20 - 1-2
jp - 21 - 1-2
  • 1 month later...
  • 4 weeks later...
spent hours today searching for what jumper 21 does, havent found any info on it with lots of forums not even talking about it.
  • 1 year later...
