M112-GZE is born :)
David P
Come for a ride in my Rocket Ship. :)
[video=youtube_share;TFb-tvM7g88]
The best bit of that clip is regaining traction in first by manually cutting the timing and slipping the torque-converter.
When it broke loose, I held the throttle steady and pressed then held the up-change button, which via the AEM cuts the ignition timing back to 6 degrees BTDC and via Suprastick unlocks the torque-converter, traction regained, I then released the button when time came to change into second.
You can't see my finger move, but it shows on the waving clocks and in among the noises.
Home made Manualised Launch Traction Control in action. :)
