dr_jekyll Posted February 9, 2010 Share Posted February 9, 2010 ge manifold £200< turbo £650 GARRET GT4088 downpipe £100< fmic £ £150 fmic piping/ couplers £90< oil feed £30< oil return £30< fuel managemnt hardware £250< afr monitoring system £150< vacume hoseing £5 b.o.v £100< wastegate / apropriate spring £65< Link to comment Share on other sites More sharing options...
Kirk Posted February 10, 2010 Share Posted February 10, 2010 Injectors should be on the list. Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 16, 2010 Share Posted February 16, 2010 well this is the basics as said, allough for 8psi and under injectors are not a must but would allways be a good idea . min can comfortably over fuel on WOT at 7psi on my 330s. i think a good fuel pump is more important the low boost setups but feel free to add parts i may have missed Link to comment Share on other sites More sharing options...
Guest icemanv6 Posted February 16, 2010 Share Posted February 16, 2010 Guy's would it be possible you could put a rough cost for the part's (from new). Next to each part, so the guy's get an idea of what price range there looking at to help to figure out a cost of purchasing parts etc, also anyone who's gone NA-T would help if they coul post how much there set-up cost them (parts) and (fitting, if took it to somewhere to get done). Cheers Link to comment Share on other sites More sharing options...
dr_jekyll Posted February 18, 2010 Share Posted February 18, 2010 i have added a rough priceing guide. basicly the < means the price given is budget stuff and the price is from that upwards depending on budget Link to comment Share on other sites More sharing options...
steve spedd Posted February 23, 2010 Share Posted February 23, 2010 maybe thats the basic and then there is the 'stage one' which would be: TT headgasket Injectors Fuel Pump different wastegate spring or a boost controller re-map Link to comment Share on other sites More sharing options...
Guest supspower Posted March 12, 2010 Share Posted March 12, 2010 Dont forget clutch, might be lucky at 7psi and your clutch might hold out for a while but i guarantee you it WILL slip sooner or later so best account for a aftermarket clutch Link to comment Share on other sites More sharing options...
HadeS Posted August 19, 2010 Share Posted August 19, 2010 Are you going to change thicker HG to TT pistons for droping down compresion? I think I will start rebuild of my na engine, after TT transplant so no rush but long term project (400bhp+). If I'll get round to it I'll upload some pics. Link to comment Share on other sites More sharing options...
Guest Fly Posted January 13, 2013 Share Posted January 13, 2013 Obviously a big cost for builders is going to be the unit itself. Are there other, lower cost turbos that would be sufficient for up to 500 bhp let's say. I ask because I have a k27 turbo .72 ar I think it is in excellent condition ready for a future project that I wouldn't mind using in a DIY kit Link to comment Share on other sites More sharing options...
Guest Fly Posted January 17, 2013 Share Posted January 17, 2013 Do we need to add a fuel cut defender to the above list ? or is this just if we go over 1 bar boost?? Link to comment Share on other sites More sharing options...
Noz Posted January 29, 2013 Share Posted January 29, 2013 This should be a list of basic stage NA-T parts, a HG lowered compression and a fuel pump isn't basic. Stock injectors can run an NA-T setup. No idea why people keep insisting injectors for NA-T basic setups when so many run stock ones. Link to comment Share on other sites More sharing options...
Guest Fly Posted January 31, 2013 Share Posted January 31, 2013 I think it's because most aim for 400 bhp from the off nd like many, me included assume the 330s won't cut it Link to comment Share on other sites More sharing options...
FOSTA Posted February 3, 2013 Share Posted February 3, 2013 Our NA-s don't need a fuel cut defender as they didn't have turbos from the factory! Lol Fuel cut is a safety device installed to turbo cars ecus to save the engine incase the turbos start to overboost! An NA shouldn't have that problem Link to comment Share on other sites More sharing options...
FOSTA Posted February 3, 2013 Share Posted February 3, 2013 Yeah I'm at 372.6bhp on stock injectors. Link to comment Share on other sites More sharing options...
Guest Fly Posted February 13, 2013 Share Posted February 13, 2013 Might also want to add 30 for your Lexus union bolt!!! Link to comment Share on other sites More sharing options...
walkerstrider Posted March 26, 2015 Share Posted March 26, 2015 On a basic setup do you need to change the ecu? Link to comment Share on other sites More sharing options...
Dazzi Posted March 27, 2015 Author Share Posted March 27, 2015 You don't need to change the ecu on a basic setup but you need to add a piggy back ecu like the emanage ultimate to tune the car to read boost. Link to comment Share on other sites More sharing options...
