Power steering failure
Rob
As I was due to pick up my new rear tyres today, I decided to shred the old ones. Whilst performing an extended doughnut the power steering packed up.
No warning lights are on, no hoses are loose, no fluid is leaking and the belt is still on.
Any ideas?
Does the pump have a motor?
I have heard of an autobox basically melting itself when soembody was doing extended doughnuts, be very sure you have a well service auto box if you want to give this a go. And yes, there is a power steering pump but never heard of it failing just like that, normally throws up a load of noise before hand.
JB
The exact same happened to mine last year while I was doing a huge doughnut at Crail, infront of loads of people and the fastcar cameras, i just couldn't help myself on the oval ring.
Anyway it turned out that it was the valves in the pump that had completely worn down because of the doughnut action. had to get the pump reconditioned but its still not working right so i'm taking it back to get fixed next week. Cost me £180 to get it sorted, and i was quoted about £430 from Toyota for a new one.
I suppose if there was a way of temporarily disconnecting the pump then burnouts on old tyres wouldn't be a problem, is there an easy wasy of doing this?
Jonny
No the pump doesnt have a motor but it does have a solenoid operated control vv which is what gives you the varying stifness, the solenoid is situated on the steering rack and takes its signal from the power steering ecu which in turn takes its signal from the speed sensor. I hope to god that you havnt burnt out the solenoid as its £330 + vat from toyota and most scrappies wont split the steering rack to give you the vv. If you want i can give you a few tests to run first to narrow the problem down.
mainly resistance tests through the solenoid and ecu (power steering) and also a full power test on the solenoid, if you are happy/ have a tester then i will dig out the page in my manual and post it.
The man from Toyota, he say "new Power Steering Rack", so it sounds a lot like Mos's solenoid gone kaput to me.
No price yet from Toyota, but based on the above at £330. Thats means my 2 minute burnout cost £330, or £9900 an hour of fun.
Has anyone spent more than this for "fun"?
If they do change your rack and vv together what would you do with your broken one, if you are just going to bin in then i will give you something for the solenoid vv as i would like to get one apart and see how hard it would be to refurbish one of these units. Please let me know either way.
