RZtwin Posted October 18, 2020 Share Posted October 18, 2020 (edited) Is this the proper way to wire new Bosch knock sensors? My jdm supra 2jzgte currently has 1 wire going to each oem knock sensor. Using Haltech elite 2500. 1. Does polarity matter??? 2. Do I NEED to ground shielding mesh to body ?? Edited October 22, 2020 by RZtwin (see edit history) Quote Link to comment Share on other sites More sharing options...
RZtwin Posted October 20, 2020 Author Share Posted October 20, 2020 Anyone? Quote Link to comment Share on other sites More sharing options...
StainedBedSheet Posted October 22, 2020 Share Posted October 22, 2020 [quote name='RZtwin']Is this the proper way to wire new Bosch knock sensors? My jdm supra 2jzgte currently has 1 wire going to each oem knock sensor. 1. Does polarity matter??? 2. Do I NEED to ground shielding mesh to body ?? [url=https://ibb.co/Chv75zD][url]https://i.ibb.co/Chv75zD/20201014-141255.jpg[/url][/url] [url=https://ibb.co/RcBdw5h][url]https://i.ibb.co/RcBdw5h/20201018-121750.jpg[/url][/url] [url=https://ibb.co/WttYZK6][url]https://i.ibb.co/WttYZK6/20201018-104210.jpg[/url][/url][/QUOTE] Are you using a stock ecu or standalone? Quote Link to comment Share on other sites More sharing options...
RZtwin Posted October 22, 2020 Author Share Posted October 22, 2020 Haltech elite 2500 ecu Quote Link to comment Share on other sites More sharing options...
RajR34 Posted December 1, 2020 Share Posted December 1, 2020 Did you get your answer to this? I can help if need be, I just did mine, to a Haltech Elite also... Quote Link to comment Share on other sites More sharing options...
RZtwin Posted December 1, 2020 Author Share Posted December 1, 2020 Hello, I would very much appreciate any info on this topic as I have not finished this portion of my build yet. Thank you RajR34. Quote Link to comment Share on other sites More sharing options...
RZtwin Posted December 19, 2020 Author Share Posted December 19, 2020 Help me install my 2 Bosch knock sensors please Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 19, 2020 Share Posted December 19, 2020 2 Wires needed for Bosch knock sensor. 1 Wire to Knock Signal, other wire to sensor ground. Ground shield wire to chassis or power ground. Polarity does not matter. If you are running two knock sensors, you can have them share signal ground and shield ground. Knock signal must be independent. Quote Link to comment Share on other sites More sharing options...
RZtwin Posted December 19, 2020 Author Share Posted December 19, 2020 10 minutes ago, Mike2JZ said: 2 Wires needed for Bosch knock sensor. 1 Wire to Knock Signal, other wire to sensor ground. Ground shield wire to chassis or power ground. Polarity does not matter. If you are running two knock sensors, you can have them share signal ground and shield ground. Knock signal must be independent. Thank you Mike! Can I use the existing old factory signal wires to the new Bosch knock sensors and use a NEW shielded wire from knocks too Haltech ecu? Does my diagram look correct? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 19, 2020 Share Posted December 19, 2020 I mean you could, but if you are having to run a shielded wire, then I don't see why you would use the OEM signal wire. Just use two core shielded wire and run it from the sensor down to the ECU. You must make sure that signal and ground wires are shielded otherwise you can get very bad electrical interference. Quote Link to comment Share on other sites More sharing options...
