Fulcrum2000 Posted October 16, 2020 Share Posted October 16, 2020 Hi All I am at the final stages of BPU now and after many problems I just need help with my boost controller. I have a Gizzmo V4 OLED installed but after having all the vacuum lines put back to stock I need to know how you install them to the two turbos can anyone please help? I've been trying to get this car safely up to BPU for 3 and a half years and still not managed. My new mechanic says he needs a diagram or description of how to attach them as the two turbos are connected it is not clear, so can anyone please tell me how you get the Gizzmo to work up to 1.2bar total BPU? I thought it would be a case of just connecting it to the second turbo but he says as some of the pressure goes from the first turbo to the second that isnt the case. Does anyone know exactly what vacuum lines go where? As I say everything is now stock vacuum wise but all other elements (restrictor ring FCD etc etc) are installed. I've looked all over Google and there's nothing. Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 16, 2020 Author Share Posted October 16, 2020 Just to clarify the vaccum lines are stock, and the Gizzmo has power but is as yet only waiting on the correct vacuum layout, any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 16, 2020 Share Posted October 16, 2020 (edited) https://www.hks-power.co.jp/en/product/electronics/boost/evcs/index.html Or this https://www.toyota-supra.com/blogs/post/61/boostcontroller-hks-evc-s-einbau-setup This may help Edited October 16, 2020 by wile e coyote (see edit history) Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 16, 2020 Author Share Posted October 16, 2020 https://www.hks-power.co.jp/en/product/electronics/boost/evcs/index.html Or this https://www.toyota-supra.com/blogs/post/61/boostcontroller-hks-evc-s-einbau-setup This may help Cheers but isnt this for a 3 point boost controller - has anyone achieved BPU with a standard 2 point controller like all but the HKS have or has everyone had HKS since the beginning of BPU? If I have to buy an HKS I will but I just assumed as most instructional threads on attaining BPU dont mention you need exclusively an HKS BC it must be possible with any competent BC to achieve the same? Does anyone have a gizzmo running BPU? Thanks in advance for any help I have my car at a garage waiting for advice Quote Link to comment Share on other sites More sharing options...
Scooter Posted October 16, 2020 Share Posted October 16, 2020 Is it worth a call to Horsham developments............I'd never heard of a Gizzmo controller before to be honest but they might be able to advise? What boost do you get at present? The restrictor ring could/should be ground out to the minimum boost you'll ever want (1.0bar?) then a controller to up it from there. Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 17, 2020 Author Share Posted October 17, 2020 Is it worth a call to Horsham developments............I'd never heard of a Gizzmo controller before to be honest but they might be able to advise? What boost do you get at present? The restrictor ring could/should be ground out to the minimum boost you'll ever want (1.0bar?) then a controller to up it from there. I'm getting just under 1 bar on restrictor - removed all the non conventional vacuum lines etc and am just trying to get the 1.2 through the Gizzmo but cant find anything anywhere to even begin to line it up - Have I missed something here, does everyone who goes BPU with twins use a HKS? If so I can go back to this but its the first time it's come up so I am a bit baffled, I thought any good EBC would be fine? Quote Link to comment Share on other sites More sharing options...
Rob W Posted October 17, 2020 Share Posted October 17, 2020 (edited) Maybe looking at the old Blitz Boost Controller installation guide might help you. It’s a 2-port boost controller, I used to have the Blitz SBC-ID Spec R fitted for years before I changed to the HKS EVC 6-IR. https://web.archive.org/web/20050327033044/http://www.mkiv.com/techarticles/blitz_dsbc/index.html Edited October 17, 2020 by Rob W (see edit history) Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 17, 2020 Author Share Posted October 17, 2020 Maybe looking at the old Blitz Boost Controller installation guide might help you. It’s a 2-port boost controller, I used to have the Blitz SBC-ID Spec R fitted for years before I changed to the HKS EVC 6-IR. https://web.archive.org/web/20050327033044/http://www.mkiv.com/techarticles/blitz_dsbc/index.html Thanks Rob I will show this to the mechanic and hopefully we will be able to jump this final hurdle! Just out of interest am I the only Supra owner out there whose installed a Gizzmo then? That was a spot of bad luck for me if so! Quote Link to comment Share on other sites More sharing options...
Ric Posted October 17, 2020 Share Posted October 17, 2020 (edited) nothing link here https://lmgtfy.app/?q=supra+install+boost+controller+diagram&t=i Edited October 17, 2020 by Ric (see edit history) Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted October 17, 2020 Share Posted October 17, 2020 nothing link here https://lmgtfy.app/?q=supra+install+boost+controller+diagram&t=i Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 17, 2020 Author Share Posted October 17, 2020 nothing link here https://lmgtfy.app/?q=supra+install+boost+controller+diagram&t=i Hi Ric Sorry you've lost me on that one Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted October 17, 2020 Share Posted October 17, 2020 Hi Ric Sorry you've lost me on that one I'm guessing type what he put into Google and look at the images Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 17, 2020 Author Share Posted October 17, 2020 I'm guessing type what he put into Google and look at the images If only it were that easy, I was searching for hours before I came on here to ask all you friendly forum types Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 24, 2020 Author Share Posted October 24, 2020 [quote name='Fulcrum2000']Thanks Rob I will show this to the mechanic and hopefully we will be able to jump this final hurdle! Just out of interest am I the only Supra owner out there whose installed a Gizzmo then? That was a spot of bad luck for me if so![/QUOTE] Just wanted to thank Rob and everyone for their help with BPU - this info, along with a specialist I've found who actually know about Supras for once have cracked it and I am now full BPU running through just a boost controller. Finally! Now just need to start all over again with a respray! Quote Link to comment Share on other sites More sharing options...
