Aquamist Water Injection Kit DDS3 V8 SOLD
TRD-1
Hi Guys,
Searching through my garage I found this kit that I brought years ago from a member on here but I never fitted it and niether did I test it. When the kit was removed by the previoius owner all the wiring has been cut, some of it is labelled some isn't, I was sold it saying its all working if connected up. If your good with wiring it doesn't seem to difficult to join everything back together please bare this in mind and check out the pics. If you have anymore questions or want anymore detailed pics message me. I believe everything you need is there to make this work including the controller, gauge, pump, flow sensor, pressure sensor, some wiring, you might need to make up some looms to extend any of the wiring and also install any new connectors as needed.
Its the Aquamist DDS3 V8 kit, you can see the manual for it on the below link, everything seems quite new so I don't know how long it was on the car before being removed. Also the pump is a Race version however the mount points have been cut and modified on one side, some of the sensor wiring has already been pre installed into a Supra washer bottle.
http://www.aquamist.co.uk/forum/gallery/DDS3v8/DDS3-v8-web.pdf
Price £SOLD
Edited by TRD-1 (see edit history)
  • TRD-1 changed the title to Aquamist Water Injection Kit DDS3 V8 SOLD
