Danhook97 Posted October 11, 2020 Share Posted October 11, 2020 Alright guys, i currently own a auto and i purchased a w58 full conversion. However due to the change of plans with power the w58 would not cope reliably. Im looking to go r154 are these a direct fit? Will i be able to use the prop from the w58? Thanks! Link to comment Share on other sites More sharing options...
AC93 Posted October 11, 2020 Share Posted October 11, 2020 R154 will be a straight swap if it has the JZ bellhousing. You'll need the front half of the R154 prop too and mate it to the rear half Supra prop. Or get a custom propshaft made up for a few hundred quid Link to comment Share on other sites More sharing options...
Danhook97 Posted October 11, 2020 Author Share Posted October 11, 2020 R154 will be a straight swap if it has the JZ bellhousing. You'll need the front half of the R154 prop too and mate it to the rear half Supra prop. Or get a custom propshaft made up for a few hundred quid Awesome, so does that mean i can mate the front half of the r154 prop too the w58 prop? Or just go custom? Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 11, 2020 Share Posted October 11, 2020 What diff do you have? Does it have the small or large companion flange? Link to comment Share on other sites More sharing options...
Danhook97 Posted October 12, 2020 Author Share Posted October 12, 2020 What diff do you have? Does it have the small or large companion flange? The car is a auto na aerotop, i wouldnt have a clue sorry Link to comment Share on other sites More sharing options...
Mk4Gaz Posted October 12, 2020 Share Posted October 12, 2020 If it has the large flange, the w58 rear won't bolt up. I don't know what the na auto came with Link to comment Share on other sites More sharing options...
AC93 Posted October 13, 2020 Share Posted October 13, 2020 N/A auto will be a small flange.. A01A diff usually. Link to comment Share on other sites More sharing options...
Danhook97 Posted October 13, 2020 Author Share Posted October 13, 2020 (edited) If it has the large flange, the w58 rear won't bolt up. I don't know what the na auto came with So as it most likely has the small flamge the w58 prop will be fine to mate to the r154? Edited October 16, 2020 by Danhook97 (see edit history) Link to comment Share on other sites More sharing options...
Iky Posted October 17, 2020 Share Posted October 17, 2020 Dan, you`ve got my friend Manos`s Supra. If I remember right, he had the diff changed possibly. Link to comment Share on other sites More sharing options...
Danhook97 Posted October 17, 2020 Author Share Posted October 17, 2020 Dan, you`ve got my friend Manos`s Supra. If I remember right, he had the diff changed possibly. Hi mate! Oh really? I dont suppose there is any way of contacting manos to find out is there? Would be a great help Link to comment Share on other sites More sharing options...
