Discs and pads recomendations
suprano
Hi,
I got my TT brakes from a guy in the US running high HP so mine came with Stoptech drilled and slotted discs and aggressive pads (which are surprisingly good even without heat in them), so someone else would need to recommend something easier to get from the UK (maybe OEM discs with CW pads?), I can however help you with the size differences, see them below:
UK (4p/2p)
Front - 323mm diameter 30mm thick
Rear - 324mm diameter 16mm thick
Jap (2p/1p)
Front - 296mm diameter 32mm thick
Rear - 307mm diameter 16mm thick
