Dnk Posted September 21, 2020 Share Posted September 21, 2020 Anyone used it ? Got a small self tapping screw in one of my new Michelins, took it out and its got a very slow leak, can't be repaired as its too close to the side wall Link to comment Share on other sites More sharing options...
Annabella Posted September 21, 2020 Share Posted September 21, 2020 Guess it may work like run flats that have no spare, ie Mini's, BMW, like the gunk that's sprayed in. As it says 'emergency repair'. Think if it was mine, I'd just take the hit and get a new tyre as you'll know the former puncture is there, peace of mind and all that. Link to comment Share on other sites More sharing options...
MaveriK Posted September 21, 2020 Share Posted September 21, 2020 Tried that gunk to spray in a punctured tyre, once deposited into the tyre it preceded to empty itself out of the hole and onto my shoes so i had to drive 50 miles with the tyre hanging on/off. Bought a spare, may move back to run flats but the drive is so much nicer on standard Link to comment Share on other sites More sharing options...
Dnk Posted September 21, 2020 Author Share Posted September 21, 2020 Oh well i've ordered a bottle so we'll see what happens Link to comment Share on other sites More sharing options...
Swampy442 Posted September 21, 2020 Share Posted September 21, 2020 Its not a permanent repair Link to comment Share on other sites More sharing options...
Dnk Posted September 22, 2020 Author Share Posted September 22, 2020 I took this off the RAC website so i'll give it a go, if it does what they say you'd never know you had a puncture or actually get one Slime Tyre Sealant is not to be confused with the run of the mill 'get you home' puncture repair tyre additive. Slime is an environment friendly blend of polymers, fibres, binders and congealing agents which actively plugs and seals punctures in the tyre tread area instantly. Slime is added to the tyre via the valve and remains fluid inside the tyre wall. Punctures up to 3mm wide will then be sealed the instant they happen. Slime is guaranteed to remain fluid and effective inside the tyre for 2 years. Should you wish to remove Slime simply remove the tyre from the wheel and wash it out. Link to comment Share on other sites More sharing options...
Dnk Posted September 22, 2020 Author Share Posted September 22, 2020 The leak is very slow and in approx 20 minutes driving it home it lost 10 psi hence i'm trying it Link to comment Share on other sites More sharing options...
auzzam Posted September 22, 2020 Share Posted September 22, 2020 Would be interested in seeing the results, is this on your supra? Link to comment Share on other sites More sharing options...
Dnk Posted September 22, 2020 Author Share Posted September 22, 2020 Would be interested in seeing the results, is this on your supra? No mate, i sold the Supra 7 years ago This is on my RRC Link to comment Share on other sites More sharing options...
Dnk Posted September 22, 2020 Author Share Posted September 22, 2020 Would be interested in seeing the results, is this on your supra? I'll update as i go, i should have it tomorrow Link to comment Share on other sites More sharing options...
David P Posted September 22, 2020 Share Posted September 22, 2020 (edited) If the puncture is deemed too dangerous to be legally repaired by professional vulcanised means, must surely dictate that is is even more dangerous to be bodged with Tyre Slime. Edited September 22, 2020 by David P (see edit history) Link to comment Share on other sites More sharing options...
Boyne Posted September 23, 2020 Share Posted September 23, 2020 Take it to small local tire business he will fix it, nonsense this just trying get you buy new tire. Link to comment Share on other sites More sharing options...
Dnk Posted September 25, 2020 Author Share Posted September 25, 2020 (edited) Tyre slime is in, i've set the pressure and noted the time, will go out and see what the pressure is in an hour or so Edited September 25, 2020 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted September 25, 2020 Author Share Posted September 25, 2020 Tyre slime for me even though i followed the instructions exactly didn't work Lost 10 psi in 1 hour I've bitten the bullet and ordered a new tyre which will go on next week Link to comment Share on other sites More sharing options...
Graham1984 Posted September 25, 2020 Share Posted September 25, 2020 Tyre slime for me even though i followed the instructions exactly didn't work Lost 10 psi in 1 hour I've bitten the bullet and ordered a new tyre which will go on next week Probably for the best in all honesty Link to comment Share on other sites More sharing options...
Dnk Posted October 2, 2020 Author Share Posted October 2, 2020 (edited) New tyre fitted Edited October 5, 2020 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
