Brian_C1 Posted September 17, 2020 Share Posted September 17, 2020 Fulcrum I have a 1994 TT Auto ECU at home in a box I'm fairly sure, but I think it may of had an issue with manual mode not working but everything else was fine. Your welcome to take it away just cover shipping from Ireland (£10-20 max), not in the game of making money on these, it's been in the shed with 2 years and had no intention of selling anyway. I don't want a pile of PMs from other members though I know Fulcrum has an issue so mine might help him out Let me know if Scooters doesn't help solve anything for you anyway Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 17, 2020 Author Share Posted September 17, 2020 That would be fantastic and of course I would fully cover all of your costs in advance Brian. I'll let you know if Scooter's indicates it is the problem and we can go from there and thanks again! Link to comment Share on other sites More sharing options...
Scooter Posted September 17, 2020 Share Posted September 17, 2020 Did mine arrive today? say on the slip dated 15th they aim to deliver 'next working day' so would expect by today it would be? Says it was at lunchtime, fingers crossed it helps as if it does then Brian's will be a good interim (at least) solution. Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 18, 2020 Author Share Posted September 18, 2020 Hi Scooter - yes its arrived, I'll get the Supra's carpet up at the weekend and do the old switcheroo then see what happens, thanks so much for letting me borrow it. fingers crossed it is the problem as it just doesnt feel like the gearbox, other than first gear it drives just like it always has. I'll let you all know. Link to comment Share on other sites More sharing options...
Scooter Posted September 18, 2020 Share Posted September 18, 2020 fingers crossed for you. Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 19, 2020 Author Share Posted September 19, 2020 Ok just been swapping the ECUs and want to report back. Put Scooters in and set off, first gear problem totally disappeared then got to about 35 going slowly and it started hesitating, then after about a mile it started what I can only describe as acting like it was struggling to get fuel, jerking etc, then it cut out completely. I tried to restart it but it just ran for a second and cut out, then I totally turned it off and re-started the car which I assume acts like a reset to the ECU and it started, but whenever it went into gear it either cut out or drove for about 20 yards then cut out. So I switched back to my ECU and the first gear fault came back immediately and constantly but the car worked exactly as before after a minute of slight misfiring which I assume came form the over fuelling after all the breakdowns. Now its totally back to normal from the get go apart from first gear. So to me this proves my fault is definitely the ECU, would we all agree? So with that in mind Brian_C1 if you are still happy to donate yours with manual not working and everything else fine I would love that, I will as agreed pay all shipping etc expenses and I will PM you in a minute. The other thing is your ECU Scooter has more problems than fourth gear missing I'm afraid, but maybe only in my car. I havent done anything whatsoever to it, not opened it and I know nothing about them so I hope you dont feel I have done anything to it, literally all I have done is plug it into my car and unplug it. It does have a slightly different part number to mine so I am wondering if its fine for you but sends the wrong signals for fuelling or sparking or whatever to mine? Probably nothing but yours has part number 175700-5990 and mine has number 175700-4821. Maybe there's just one loose pin or connection? Anyway let me know what everyone thinks Link to comment Share on other sites More sharing options...
Scooter Posted September 20, 2020 Share Posted September 20, 2020 Did you fully do up the nut when you swapped the Ecu's? I'm certain its fine obviously unless damaged in transit. Not bothered just wondering if the connections were all good (no sign of oil on the harness/connectors?) Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 20, 2020 Author Share Posted September 20, 2020 Ok let me swap them again today and really check as to be honest the symptoms do seem to look like a loose connection I just didnt want to damage the ECU or car any more so swapped back to mine but I'm happy to have another go as the carpet etc is still all up, if its still faulty and has been damaged in transit in some way how about you keep the deposit and I send it back to you at my expense as obviously it's not your fault in any way? I'll let you know what happens anyway - but to me common sense dictates the ECU is seemingly the problem with the gears yes? Link to comment Share on other sites More sharing options...
Scooter Posted September 20, 2020 Share Posted September 20, 2020 Can't be 100% sure what the problem is remotely, but send it back when you're done and I'll refund you the deposit no problem. I was only keeping it as a good fault funding device, I have sent it to at least one person before and it was ok for them. So on that basis I'd assume it was something else, but I'd take up the other guys offer of another one. If that gives you issues you know it's unlikely to be the Ecu. Only other thing is to try your Ecu in someone else's but not so likely people will be up for that. Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 20, 2020 Author Share Posted September 20, 2020 Hi Scooter So I swapped them back over and with your ECU it was all fine this time, I took extra care this time to make sure both plugs were tight and even blew onto the terminals and just did 15 miles stopping and starting with no problems at all other than having no 4th gear as you say. I'm well chuffed this means its defo the ECU yes? First gear is as sweet as before with yours, having no 4th gear makes for a revvy straight at 50 but point proven I think! Thanks so much for letting me borrow it, I will return it shortly if you give me your address on a PM Brian I have sent you a PM but not sure if they dont work too well at the moment? None of mine seem to ever appear in the sent items so not sure if you got it? I would love to pay shipping to get yours if thats still agreeable? Link to comment Share on other sites More sharing options...
Annabella Posted September 20, 2020 Share Posted September 20, 2020 Good result, nice one Scooter. Link to comment Share on other sites More sharing options...
Scooter Posted September 20, 2020 Share Posted September 20, 2020 Cheers glad it's helped, it's a great Ecu to lend out for easy fast track testing as it's perfect bar 4th gear. It's a shame we haven't got a good trusted source for repairs. Once you're sorted you can open your one up as advised or donate to someone who fancies having a look at it. No rush to return it if you want to pootle about a bit before you get another. Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 20, 2020 Share Posted September 20, 2020 Scooter said: Cheers glad it's helped, it's a great Ecu to lend out for easy fast track testing as it's perfect bar 4th gear. It's a shame we haven't got a good trusted source for repairs. Once you're sorted you can open your one up as advised or donate to someone who fancies having a look at it. No rush to return it if you want to pootle about a bit before you get another. Auto ECU's are frequently being sent in to us for repairs. Due to complexity of board(s), there is more that can wrong and they do. Shoot Lee P a message, he can get you a quote for repairs to ECU. Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted September 21, 2020 Author Share Posted September 21, 2020 Thanks for the PM Brian, hope you've received the postage ok and the address, its not showing on the Sent Items again so I'm not sure but let me know if you need anything - - - Updated - - - Mike2JZ said: Auto ECU's are frequently being sent in to us for repairs. Due to complexity of board(s), there is more that can wrong and they do. Shoot Lee P a message, he can get you a quote for repairs to ECU. Cheers Mike I would pay to have my other one fixed as a spare so I will give that some thought Link to comment Share on other sites More sharing options...
mwilkinson Posted September 24, 2020 Share Posted September 24, 2020 (edited) Non VVTi Auto Ecu for sale on the forum. https://www.mkivsupra.net/vbb/showthread.php?360176-Toyota-Supra-2JZGTE-Auto-ECU-Non-vvti Edited September 24, 2020 by mwilkinson (see edit history) Link to comment Share on other sites More sharing options...
David P Posted September 24, 2020 Share Posted September 24, 2020 It's an Aristo ECU, Supra air con doesn't work with these. Link to comment Share on other sites More sharing options...
mwilkinson Posted September 24, 2020 Share Posted September 24, 2020 David P said: It's an Aristo ECU, Supra air con doesn't work with these. He has both for sale. An Aristo and Supra Auto ECU. Link to comment Share on other sites More sharing options...
David P Posted September 24, 2020 Share Posted September 24, 2020 (edited) I missed that, but at least he now knows which one not to buy and why. Edited September 24, 2020 by David P (see edit history) Link to comment Share on other sites More sharing options...
TRD-1 Posted September 25, 2020 Share Posted September 25, 2020 David P said: It's an Aristo ECU, Supra air con doesn't work with these. I think a way has been found by the use of a reed relay to make this work, and once wired up it works like stock on the Supra fitted with a Aristo Ecu Link to comment Share on other sites More sharing options...
Scooter Posted October 3, 2020 Share Posted October 3, 2020 Just for info, ecu all back with me and available again to send out for diagnosing issues. Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 8, 2020 Author Share Posted October 8, 2020 Mike2JZ said: Auto ECU's are frequently being sent in to us for repairs. Due to complexity of board(s), there is more that can wrong and they do. Shoot Lee P a message, he can get you a quote for repairs to ECU. Hi Mike Just trying to get hold of Lee P, is that his username? Nothings coming up on the search for me and I wanted a quote to get the other ECU fixed Link to comment Share on other sites More sharing options...
Steve Posted October 8, 2020 Share Posted October 8, 2020 Fulcrum2000 said: Hi Mike Just trying to get hold of Lee P, is that his username? Nothings coming up on the search for me and I wanted a quote to get the other ECU fixed https://old.mkivsupra.net/vbb/member.php?3141-Lee-P Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted October 8, 2020 Author Share Posted October 8, 2020 Thanks so much! Link to comment Share on other sites More sharing options...
