Peter P Posted September 8, 2020 Share Posted September 8, 2020 (edited) Hi All, Long shot and not something I need urgently as car is still with the bodyshop and will be till early 2021, but I need to try and source a good used 6-speed manual differential for my ISF gearbox conversion. I’ve asked Keron to keep me posted in case he gets any cars in for breaking with a suitable unit, but if anyone has one or spots anything that might be a good lead, I’d appreciate the heads up. Appreciate these are pretty rare and thin on the ground so I’d rather put the feelers out now. Cheers all. Pete Edited September 8, 2020 by Peter P (see edit history) Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 8, 2020 Share Posted September 8, 2020 (edited) Would probably be cheaper, easier and quicker buying a manual ring and pinion new from Mr T for the smaller A diff and fitting that to an OS Giken pumpkin. Edited September 8, 2020 by Frank Bullitt (see edit history) Link to comment Share on other sites More sharing options...
Peter P Posted September 8, 2020 Author Share Posted September 8, 2020 Frank Bullitt said: Would probably be cheaper, easier and quicker buying a manual ring and pinion new from Mr T for the smaller A diff and fitting that to an OS Giken pumpkin. Thanks, not a bad shout. Will look into it. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 8, 2020 Share Posted September 8, 2020 If you are concerned with the strength of the new parts then look at Frozen Soild - https://www.frozensolid.co.uk/ Link to comment Share on other sites More sharing options...
