trevorc Posted August 25, 2020 Share Posted August 25, 2020 I've had replaced both front lower suspension arms, brake dust sheilds, hub knuckles, oem bearing. Under 20 mph the car makes a sqeak noise like a forumula E race car, over 20mph the noise disappears and drives as normal... Car has been back to the garage and they haven't been able to diagnose the issue... They assume that as the parts were all new that there shouldn't be a lack of grease problem... I was wondering if it is the rubber bit in the bearing just rubbing at slow speed, hoping it would disappear with use. Does anyone have suggestion on what to do /check next? If it makes a difference, UK spec with ABS sensors. Link to comment Share on other sites More sharing options...
Annabella Posted August 25, 2020 Share Posted August 25, 2020 Brake pad springs? Link to comment Share on other sites More sharing options...
trevorc Posted August 27, 2020 Author Share Posted August 27, 2020 Brake pad springs? Have mentioned it to the garage, will see what they say... Link to comment Share on other sites More sharing options...
