Brad’s SRD big build supra
bradleyh_15
So I’ve owned my supra for quite some time now and 5 years ago I took it off the road to do an engine build. However as life loves to throw shit at you I had a few issues and the build was delayed as I ended up having a year off work and spent the £30k I had saved to do the rebuild.
As it stood before being taken off the road
However during that period it was dry stored in my workshop and slowly stripped down to a complete bare shell with just the front window left to be taken out. As you can see gathering a lot of dust
I made the decision that I would go for a high horse power build so got in contact with Lee at SRD and he persuaded me that a Vvti head was the way to go. However one of those isn’t cheap to buy new so I sourced a Vvti engine from an aristo
That engine is currently being stripped down
and rebuilt at SRD as we speak to the following specifications
Bottom end:
Titan 3.4 litre stroker crank
Titan oil pump drive
Manley 3.4 litre stroker pistons
Manley H-tuff+ rods
Clevite bearings
SRD brace kit with ARP hard wear
Tomei oil baffle kit
New Toyota oil pump
New Toyota water pump
All new tensioner’s
New fluidampner
PHR Black edition 4 piece pulls set
SRD 6 phase 170amp alternator
Head/ inlet:
Kelford V202-D Cam’s
BC 0310 Duel valve springs and titanium retainers
BC 2950 valve locks
BC 3930 bronze valve guides (inlet side)
BC 3931 bronze valve guides (exhaust side)
BC 3302 intake valves 1mm oversize
BC 3303 exhaust valves 1 mm oversize
Toyota shimless buckets
All machined to SRD’s stage 5 specifications
Hypertune 2JZ Big Port Inlet Manifold, 12 injector setup with 12 injector fuel rail
Turbo:
SRD Single Turbo Kit Supra,
SRD T4 Billet collector
SRD Billet Waste gate collector
4" DP and MP
60mm Screamer
76mm Intercooler pipe work with Precision V Band Flange
PT8385 Gen 2 Street Fighter
Turbo smart Gen V 60mm Power Gate
SRD Oil Feed Kit
SRD Oil return kit
Fuelling:
Aeromotive A1000 FPR, -8 ORB
PHR Triple 485 Hanger
Walbro 485 Pump
PHR Billet Under Car line holder set x5
-8 High Flow Billet Fuel Filter with 30 Micron metal filter SRD E85 safe fuel system, lines and fittings
ID1700x Injectors for 2JZ ID1050x Injectors 2JZ
Engine management/ electrics:
Syvecs S7 plus ecu
Custom Milspec Engine Harness for 2JZ - VVTI
R35 Coils
Bosch Knock Sensor for Syvecs
Toyota Knock Sensor Adapter
Boost Solenoid 4 Port
SRD Boost solenoid bracket
Syvecs Pressure Sensor
Syvecs 4 Bar to NPT
Syvecs NTK O2 Sensor.
Intercooler and pipework:
ETS 6" Intercooler Core -3 Inlet
- 3.5" Out let
- Anodised Black
Drive train and suspension/ chassis:
SRD prop
RPS Tripple Plate Strapless Carbon Clutch with Steel Billet Flywheel
OS Giken LSD JZA80 9" diff
OS Giken Diff oil 250R
SRD Billet Diff Cover Large Case Toyota Diff Fitting Kit
New Bearings
New Seals
New O rings
New Bolts
V160 gearbox
New TRD gearbox mount
Full super pro Polly bush kit
TRD engine mounts
BC racing ER series coil overs and springs
JAP speed front and rear upper, lower and tow arms fully adjustable arms
All new wheel bearings, seals, retaining clips, caps and flanges front and rear hubs
Front and rear hubs sand blasted, zinc treated and painted with new carrier bushes
New clutch release fork
New gearbox inspection covers
Shifter assembly stripped down zinc coated and painted with new bushes, dust boot, yoke control, control bracket, shaft control, shifter boot and bolts
Wheels/ Body/ interior and dress up parts:
LED front fog/ indicators
Carbon LED rear lights
prospec imports headlight carbon inserts
whifbits carbon headlight duct
Seibon carbon front wings
Seibon carbon boot lid
Carbon engine covers
Carbon spark plug cover
LED heater upgrade
New 6 speed gear knob
New centre console
Black carpet and headlining
CCW classic wheels custom sizes finished in a polished lip with a bronze centre
Recaro podium bucket seats with gosling racing fully adjustable mounts
steering wheel reconditioned by royal steering wheels
Gary England carbon spoiler blade and carbon TRD legs
full glass out respray with under seal
Brakes:
AP racing 6 pot 362mm front
AP racing 4 pot 330mm rear
portfield pads front and rear
Miscellaneous:
SRD Heater Hose Kit
SRD Custom Intercooler pipe work for Hypertune
SRD -12 Custom Breather Setup Toyota Engine
Cusco D1 40 cromoly 8 point around dash roll cage with harness bar
- - - Updated - - -
Edited by bradleyh_15
Title update (see edit history)
All new bushes, bolts and arms for the whole car not just using the sorry 20 odd year old ones that were put in when it was first made. The hubs have also had the bearing pressed out and will be getting the same treatment as soon as I get some time off work. The front sub frame will also be accompanying them before it gets reassembled with brand new arms and bolts.
Great build thread, interested to follow your progress as this has a lot of the bits I am looking to do on my build as well. :thumbs:
Please do keep it going and share as many photos as you can mate, look forward to following your progress and seeing this come together. :)
Will do mate, some times I do stuff then forget to take pictures. you staying auto box?
