Nathanj1142 Posted August 24, 2020 Share Posted August 24, 2020 Hey all, Started the engine build today using king racing std size main bearings. I just wanted to check I’ve understood the tolerances correctly following the TSRM. Plastigauge measurements as follows: 1: .038mm 2: .050 3: .050 4: .043 5: .067 6: .050 7: .050 On the TSRM it states std size clearance to be between .035mm and .053mm, however maximum can be .08mm Does it matter that some bearing clearances are outside the standard size (But still within max) and others aren’t? Interested to know cheers Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 25, 2020 Share Posted August 25, 2020 Technically will run but not ideal. You seem to have uneven wear on the crank, may cause reliability issues in future. Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 25, 2020 Author Share Posted August 25, 2020 Technically will run but not ideal. You seem to have uneven wear on the crank, may cause reliability issues in future. Interesting. How would this be corrected? Crank machining or oversized/undersized bearings? Cheers Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 25, 2020 Author Share Posted August 25, 2020 Interesting. How would this be corrected? Crank machining or oversized/undersized bearings? Cheers In addition to this (which I’ve only just thought about, I did use assembly lube when measuring, was this the right thing to do or could that cause variation in my measurements? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 25, 2020 Share Posted August 25, 2020 Crank journals and bearings need to be dry when doing plastigage ideally. Also make sure your crank does not spin or move whilst doing it. If your crank is out of whack then your only options are to: Send it and pray Grind crank to next oversize (although many people frown on this) Get another healthy crank Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 25, 2020 Author Share Posted August 25, 2020 Crank journals and bearings need to be dry when doing plastigage ideally. Also make sure your crank does not spin or move whilst doing it. If your crank is out of whack then your only options are to: Send it and pray Grind crank to next oversize (although many people frown on this) Get another healthy crank Another thing is, the plastigauge is quite old so I’m not sure if it goes ‘off’ or whatever. Didn’t look too great lol. Will order some more tonight and I’ll give it all another good clean, get rid of the assembly lube see what it’s coming out at. Machine shop said it was all within tolerance so I’m not sure Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 26, 2020 Author Share Posted August 26, 2020 update: ran the test again dry, all measurements at 0.038 with a couple clearances slightly larger between .038 and .043. I believe i had the strips set in the wrong orientation too. All happy now Quote Link to comment Share on other sites More sharing options...
markssupra Posted August 26, 2020 Share Posted August 26, 2020 update: ran the test again dry, all measurements at 0.038 with a couple clearances slightly larger between .038 and .043. I believe i had the strips set in the wrong orientation too. All happy now Well done, nothing quite like building your own engine if you can do it. When I built mine, I checked the crank and rod journals first to see if they were in tolerance. They were all good, between 10 microns (0.010mm) of each other. Did you get the block rebored? If so, did you remove the oil gallery bearings from the block to clean it out properly? Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 27, 2020 Author Share Posted August 27, 2020 Well done, nothing quite like building your own engine if you can do it. When I built mine, I checked the crank and rod journals first to see if they were in tolerance. They were all good, between 10 microns (0.010mm) of each other. Did you get the block rebored? If so, did you remove the oil gallery bearings from the block to clean it out properly? Hey mate! Yeah i thought why not, its a learning curve but i'm just taking my time and anything i'm unsure with i post on here! Block has not been rebored, only skimmed and honed then cleaned with a parts cleaner. I had the main caps measured and the crank all measured to ensure it was within spec, as i dont have micrometers etc, which i was informed it was hence why i was confused with my first set of readings. Quote Link to comment Share on other sites More sharing options...
