Selecting bearings
Dan8
Am i correct in the selection for standard bearings just wanted reassurance before ordering but obviously I will be Using plastigauge To check clearances the crank was all Well within spec
ROD Numbers 2 2 1 2 2 1
Front crank No 1 1 1 0 0 1
Block number 5 5 3 4 4 5 3
Rear crank no 4 2 2 2 3 2 1
Rod bearing numbers required for ordering
3 3 2 2 2 2
Main bearing numbers required to order
4 3 2 3 3 3 2
It’s the first time I changed supra ones Toyota way that’s all
Thanks for help
Edited by Dan8 (see edit history)
