broomie Posted August 15, 2020 Share Posted August 15, 2020 I have a leak from my exhaust side on my cam cover on 2001 NA. I have bought OEM gaskets for both sides, is there a guide or manual that will help me replacing these? I have bought new plugs aswell, thought that would be a good idea whilst the intake is off! Can anyone help? pls Quote Link to comment Share on other sites More sharing options...
mc92 Posted August 15, 2020 Share Posted August 15, 2020 https://www.shoarmateam.nl/content/mkiv-supra-tsrm/ Have a look in the TSRM manuals. Cam cover torque specs are on page 16 of the engine mechanical one. You'll need some gasket maker and a torque wrench with a low range. Removing the intake is probably in the same manual somewhere. You might find it easier to unbolt the TB and y-pipe as a single unit instead of splitting them, I do anyway. 6 bolts on the y-pipe and 4 on a bracket just above the exhaust manifold. Just make a note of where all the vac hoses and plugs go. Quote Link to comment Share on other sites More sharing options...
broomie Posted August 16, 2020 Author Share Posted August 16, 2020 https://www.shoarmateam.nl/content/mkiv-supra-tsrm/ Have a look in the TSRM manuals. Cam cover torque specs are on page 16 of the engine mechanical one. You'll need some gasket maker and a torque wrench with a low range. Removing the intake is probably in the same manual somewhere. You might find it easier to unbolt the TB and y-pipe as a single unit instead of splitting them, I do anyway. 6 bolts on the y-pipe and 4 on a bracket just above the exhaust manifold. Just make a note of where all the vac hoses and plugs go. Thank You Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 17, 2020 Share Posted August 17, 2020 With pics here....hopefully not too late! https://www.mkivsupra.net/vbb/showthread.php?4262-S-Plugs&highlight=plugs Quote Link to comment Share on other sites More sharing options...
