Nathanj1142 Posted August 12, 2020 Share Posted August 12, 2020 Good news, a load of parts for my GE motor have come thanks to TCB, including a TT oil pump as i'd like to include a crank position sensor. I have yet to order the sensor and crank pulley with the timing grooves on. Plan is to run a LINK G4+ but im finding it hard to get info on how to wire this CAS into the link. Do i just purchase that part of the loom and run accordingly to the factory ECU pinouts or is there another way? (using an NA loom) Cheers, Nathan. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 12, 2020 Share Posted August 12, 2020 Easy enough to wire it in, but first I must ask what you are planning to regarding cam sensor? No point running crank sensor without a cam sensor to compliment it Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 12, 2020 Author Share Posted August 12, 2020 Easy enough to wire it in, but first I must ask what you are planning to regarding cam sensor? No point running crank sensor without a cam sensor to compliment it was going to either use the stock dizzy as a signal or convert to 7m-gte Quote Link to comment Share on other sites More sharing options...
Noz Posted August 13, 2020 Share Posted August 13, 2020 Stick with the dizzy sensor. Keeps it easy and no need to source old 7mgte parts. Which could fail Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted August 13, 2020 Share Posted August 13, 2020 Yeah keep the dizzy. It is essentially a crank/cam sensor. Works with Link ecu as is. Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted August 13, 2020 Author Share Posted August 13, 2020 perfect. cheers guys. In terms of the crank sensor though, are there any guides on how to wire this in? should I even bother if retaining the dizzy? could i do both (dizzy and crank sensor)? i prefer reading up on things before attempting myself. Cheers Quote Link to comment Share on other sites More sharing options...
