jza800 Posted August 1, 2020 Share Posted August 1, 2020 (edited) Hi I have a gab about 150mm to 170mm between the intercooler pipe that goes from the intake to the pipe that connect to the intercooler because the intercooler pipes cannot reach each other , can i just run a 200mm silicon hose on that gab, or do i have to find a 100mm pipe to put in between the hoses?? and how much it will expand if you drive with a boost pressure of maximum 1.5 bar? because i have the ac lines over there, and i know the pipes runs very close to the ac connectors there, so if it expand to much i am afraid it would make a hole in the silicon hose?? Edited August 1, 2020 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 2, 2020 Share Posted August 2, 2020 Quick search i found this on ebay , Aluminium 100 mm dia, 200 mm long with swaged ends for £11.64 https://www.ebay.co.uk/itm/Aluminium-Polished-Alloy-Joiner-Silicone-Hose-Metal-Swaged-Connector-Beaded-Pipe/392693605204?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D227677%26meid%3D915eb79eef844eb4b554c702e9e4a6dd%26pid%3D100005%26rk%3D4%26rkt%3D12%26mehot%3Dco%26sd%3D184119800702%26itm%3D392693605204%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithDarwoV2BBEV1%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851 Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 2, 2020 Author Share Posted August 2, 2020 (edited) Quick search i found this on ebay , Aluminium 100 mm dia, 200 mm long with swaged ends for £11.64 https://www.ebay.co.uk/itm/Aluminium-Polished-Alloy-Joiner-Silicone-Hose-Metal-Swaged-Connector-Beaded-Pipe/392693605204?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D227677%26meid%3D915eb79eef844eb4b554c702e9e4a6dd%26pid%3D100005%26rk%3D4%26rkt%3D12%26mehot%3Dco%26sd%3D184119800702%26itm%3D392693605204%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithDarwoV2BBEV1%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851 i found that too, but can i use a hose instead of the pipe? as i think 4 clamp so close take much space.. so that is way i was wondering if i could use a straight silicone hose there? Can i just put a hose in between there, as you can get a hose in 76mm and 200mm long? Edited August 2, 2020 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 2, 2020 Share Posted August 2, 2020 I'd replace the pipe that's too short with another hard pipe Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 2, 2020 Author Share Posted August 2, 2020 I'd replace the pipe that's too short with another hard pipe I can't do that as i can not get that hard pipe longere, it is the one that connect on the intake, and the other goes to the intercooler, so i can't find some that are longere.. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 2, 2020 Share Posted August 2, 2020 I can't do that as i can not get that hard pipe longere, it is the one that connect on the intake, and the other goes to the intercooler, so i can't find some that are longere.. What intercooler kit do you have fitted ? Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 2, 2020 Author Share Posted August 2, 2020 What intercooler kit do you have fitted ? some unknown intercooler kit from ebay. meade to supra twin turbo Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 2, 2020 Share Posted August 2, 2020 some unknown intercooler kit from ebay. meade to supra twin turbo Think i'd be buying a known kit that fits to be honest, had no issues with my HKS intercooler and pipes Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 2, 2020 Author Share Posted August 2, 2020 Think i'd be buying a known kit that fits to be honest, had no issues with my HKS intercooler and pipes I had a perfect fit on this kit, it is after i have build another bumper to mine, after my widebody build, the changes i did on the bumper is the cause of this now. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 2, 2020 Share Posted August 2, 2020 Take it to a fabricator to weld an extra section onto that pipe. Introducing extra hose joints in the system is Introducing extra potential failure points, as would be bodging a universal piece of silicone pipe to join that gap. Quote Link to comment Share on other sites More sharing options...
Noz Posted August 2, 2020 Share Posted August 2, 2020 He may need a joiner anyway. Depending how its piped welding then together may not be an option. Might make it unable to come off the car if he creates a loop. Always opt to weld over silicone. For this instance. I would use a piece of pipe and two separate joiners. Yes its a pain in the ass to get two silicone pieces and a bead on the lips. Silicone may be able to take the pressure of the internal boost. But that angle may cause the silicone to deform to a shape that restricts flow. Conclusion. If you cant weld it. Add a piece of pipe! Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 3, 2020 Share Posted August 3, 2020 I had a perfect fit on this kit, it is after i have build another bumper to mine, after my widebody build, the changes i did on the bumper is the cause of this now. Not sure how that affects the FMIC pipes, i had TRD widebody with no need to change the cooler pipe work Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted August 3, 2020 Share Posted August 3, 2020 Mine has a silicone coupler there with no drama at 500bhp Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 3, 2020 Author Share Posted August 3, 2020 Thanks for all the replies, i have bought a 100mm pipe with Swaged Beaded and 2 silicon couples, so i hope that will work for now Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 3, 2020 Share Posted August 3, 2020 Thanks for all the replies, i have bought a 100mm pipe with Swaged Beaded and 2 silicon couples, so i hope that will work for now I'd be interested to see your pipe set up Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 3, 2020 Author Share Posted August 3, 2020 why? what do you want to see that is not already shown? Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 3, 2020 Share Posted August 3, 2020 why? what do you want to see that is not already shown? Just interested to see the area your having the problem with Quote Link to comment Share on other sites More sharing options...
jza800 Posted August 3, 2020 Author Share Posted August 3, 2020 Just interested to see the area your having the problem with There is a picture of that already, it is from the 180 degress pipe from the intercooler , to the pipe there is connected on the intake manifold Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 4, 2020 Share Posted August 4, 2020 There is a picture of that already, it is from the 180 degress pipe from the intercooler , to the pipe there is connected on the intake manifold sorry for some reason the photo i didn't see, no idea why Quote Link to comment Share on other sites More sharing options...
