leon_83 Posted July 30, 2020 Share Posted July 30, 2020 Hello to everyone, I need your help... I am installing the greddy profec oled ebc, and I would like to have some advice on which is the best spot from to take the boost pressure source to power the greddy oled control unit, not the solenoid. for now I have used a "T" fitting on the OEM pressure sensor tube located on the intake manifold (from the side that gives on the valve cover; many peoples use it as a source for the boost gauge. ic attached). but I would like to find a different, more reliable and direct source (the hose is only 1/8 "and therefore it could blow away). Furthermore, the greddy manual says:" For Toyota's JZ engines, Mitsubishi's 4G63 engines and engines with fuel pressure controlling solenoids, make sure to tap the pressure in between intake manifold and fuel pressure control solenoid. (do not install on the line between the fuel pressure control solenoid and fuel pressure regulator.) ". what other source can i use safely and reliably as a boost pressure source? Quote Link to comment Share on other sites More sharing options...
