Urgent Help - Where can I buy this plug
KingCole
Hi guys,
I need urgent help trying to figure out where to buy the plug or have a part number as seen in the diagram. Also does anyone have the wiring diagram for this too?
This is used in a RHD Mk4 Supra door harness with Part No 82151-14591.
Thanks
Edited by KingCole (see edit history)
You need to find plug reference charts like this one and then you can identify the plug by a direct comparison with the one that is hopefully still on the loom just in need of replacement, once you have that you can scour the earth or I have had TCP Parts track it down for me once I know what to ask them for. If you look through the workshop manuals that are on this site you'll probably find one with all the wiring plugs detailed. Its unlikely that anyone will be able to answer your specific question so a bit of self help investigative time may well be your best friend here.
Thanks for your response.
Unfortunately, the original plug was crushed so I don't have it but I do have pictures of plug on the passenger side which goes in the same location but on passenger side. I am not sure if they are the same but here are some pictures. it is a 4-pin plug probably used for the lock actuator.
You need to look straght into the plug and then you can see which configuration of number of pins, position of pins and outline matches the plug diagram. Sometimes, the plug will have the type stamped on it.
Using the link Scooter offered up its an H6 plug you need.
What a legend mate!!!!! Thank you!!!!!!
Also thanks to scooter!
Rider - Can you please advise how to get a part number for the plug? or is H6 connector unique across all toyota models?
  • 1 month later...
Hi guys,
I need your help again, does anyone have the pinout for this plug? As I mentioned, the original plug was destroyed and I am not sure which wires go where. Thanks in advance.
Cheers
Cole
I believe it's on this diagram. Pin 1 being Blue/White, 2 being Blue/Yellow, 3 White/Black, 4 Blue/Red.
Edited by mc92
inability to read (see edit history)
[ATTACH=CONFIG]237721[/ATTACH]
You are 100% correct about the colours of the wires and where they go as I have the actual wire. I am trying to understand/read the diagram better, where on the diagram does it say Blue/White? It just says "LW" so how did you figure out that "L" actually refers to Blue wire?
At the end of my wiring diagram PDF there's a small section on wire colours.
Wire colors are indicated by an alphabetical
code.
B = Black L = Blue R = Red
BR = Brown LG= Light Green V = Violet
G = Green O = Orange W = White
GR= Gray P = Pink Y = Yellow
The first letter indicates the basic wire color and
the second letter indicates the color of the stripe.
code.
Thank you!!!!
