Dave Posted July 17, 2020 Share Posted July 17, 2020 (edited) Been out today and my front wipers are not working rears ok and washers ,took the panel off and the motor is hot ,any help would be appreciated thanks . So stripped it down nothing visual cleaned and oiled put it back it just clicked ,so I’ve got power to it the relay must be ok . Edited July 17, 2020 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 17, 2020 Share Posted July 17, 2020 I would visually inspect the fuse. I would then check the resistance across the relay pins (switched!), and if that's okay, check the resistance of the wiring. Just because you have voltage doesn't mean there isn't a fault in the circuit somewhere, affecting amperage That said, I would imagine its a fault with the motor in the wiper mechanism, but there's no point spending money on a fix until you've reasonably exhausted checks/testing which don't cost a thing Quote Link to comment Share on other sites More sharing options...
Dave Posted July 17, 2020 Author Share Posted July 17, 2020 (edited) I would visually inspect the fuse. I would then check the resistance across the relay pins (switched!), and if that's okay, check the resistance of the wiring. Just because you have voltage doesn't mean there isn't a fault in the circuit somewhere, affecting amperage That said, I would imagine its a fault with the motor in the wiper mechanism, but there's no point spending money on a fix until you've reasonably exhausted checks/testing which don't cost a thing Thanks for the advice the fuse also controls the rear wiper which works ok ,as for auto electrics im clueless ,I have a multimeter , any advice on the testing procedure would be great I also noticed when I stripped the motor that the two magnets were loose I’m assuming they should be stuck to the side of the case Edited July 17, 2020 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
