Will those alloys fit Supra?
Bender
Hi im after new set of alloys and find one which is quite my taste but dont know if they gonna fit so spec are Wheel Size: 18"
Rim Width: 10.5"
Offset : ET15
Wheel Colour: Bronze
Bolt Pattern (PCD) : 5x114.3
Centre Bore: 73.1
Im worring they will be too wide with 10.5" as on that size i need at least 265 (front) and i guess 285 on the back did they also clear uk brakes?
Thanks in advance
PS. I wish taptalk will still work on this forum :-(
Hi, The alloys your referring to belonged to suprano a member on here who ran 265 tyres at the rear on these alloy wheels and I think was 235 on the front but you would have to confirm with him.
I've got 17x9+20 on the rear of my NA and it fits nicely (and could come out 5mm or so and still be within the arch), so you'd be able to go to 9.5+20/25 as a max I'd say. Unfortunately I've got no photos and the car is away at the bodyshop at the moment.
I use: https://www.willtheyfit.com to check, so if you know your current setup, you can play about with the numbers to see what will fit based on your existing setup.
Hope this helps!
Hi, I own the bronze wheels on eBay there my spare set of wheels, I’m thinking of getting the supra back out of storage and putting the wheels back on my car with new 265 or 275 on the rear and 235s on the front.
  • 2 weeks later...
