Mr2kyle Posted July 12, 2020 Share Posted July 12, 2020 Hi folks, Just wondering what some of you may have done to try and deter people from stealing your car other than putting it into a garage or parking other cars in front of it. I’ll have an alarm fitted and also a wheel lock added. I’m thinking of fitting a kill switch for the fuel pump also. Any other ingenious ways? Link to comment Share on other sites More sharing options...
Dnk Posted July 12, 2020 Share Posted July 12, 2020 I read lots of people are fitting these https://www.ghostcarimmobiliser.co.uk/ Link to comment Share on other sites More sharing options...
rider Posted July 12, 2020 Share Posted July 12, 2020 7 dogs. Lots of local farms have break ins - we seem to get overlooked. Link to comment Share on other sites More sharing options...
Johnm400 Posted July 12, 2020 Share Posted July 12, 2020 I think a kill switch is good idea as long as you tap into the loom behind the dash where it cant be seen and can isolate something that cant easily be bypassed. Then you need to think about finding somewhere to hide the switch, perhaps behind the dash somewhere where you can just about get to it and it cant be seen. My car has an alarm and immobiliser that was fitted when i got the car, its garaged with an alarm on the garage and ive got CCTV pointing at both garage doors and i never leave it parked anywhere else otherwise i would deffo fit a kill switch. Im more concerned about being hijacked when im putting fuel in or opening the garage door to be honest but if you're a big dude that eats his corned beef i guess thats less likely to happen. Link to comment Share on other sites More sharing options...
Mr2kyle Posted July 12, 2020 Author Share Posted July 12, 2020 Cheers dnk that seems like a good thing to have as well as a normal alarm as it doesn’t seem to do locking or anything like that. Any advice on any alarms in particular? I had a laser alarm fitted and then put the car into the body shop where they then managed to dismantle half the alarm so now that’s a load of scrap! 500 quid down the drain.wish I could get the original key for and alarm to work. Link to comment Share on other sites More sharing options...
Mr2kyle Posted July 12, 2020 Author Share Posted July 12, 2020 Hi john, I think I will do that but I might actually put the switch in the boot close to where the pump is. It wouldn’t be the first place someone would look as it’s not exactly a convenient place. It’s just for when I leave the car overnight. Not for if I just go into a shop or a restaurant. Link to comment Share on other sites More sharing options...
Scooter Posted July 12, 2020 Share Posted July 12, 2020 When I've left mine for a while I removed one of the efi 30amp fuses. Not exactly a hard thing to sort but it's not like an opportunist can start going through a check list of what might have been fitted/removed, might make you feel better until you sort better additional security Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 12, 2020 Share Posted July 12, 2020 Cheers dnk that seems like a good thing to have as well as a normal alarm as it doesn’t seem to do locking or anything like that. Any advice on any alarms in particular? I had a laser alarm fitted and then put the car into the body shop where they then managed to dismantle half the alarm so now that’s a load of scrap! 500 quid down the drain.wish I could get the original key for and alarm to work. I’m looking into this at the moment. I need a new alarm after the original one has a fault. I’m hearing that it may be preferable to fit an older model alarm due to the thicker wiring that’s used that matches the era of our cars; with modern alarms having wires that are a bit thinner to match modern wiring looms. Just what I was told. Link to comment Share on other sites More sharing options...
bluecoupe46 Posted July 12, 2020 Share Posted July 12, 2020 (edited) I've got a GPS tracker with geofencing (if it moves out of the zone it texts me it's location, speed, direction and a Google map link every 2 minutes). I can set it to text me updates up to a maximum of every 10 seconds. It is also wired into the ecu power so I can text a code with a password I set and it will kill power to the car so it won't run. I can also listen to what's being said in the car with it, and it's battery lasts 90 days, however it's also constantly plumbed into the car battery too. So once the car battery dies its got 90 days of charge. I also plan on installing a kill switch to the automatic gearbox position sensor so it thinks the gearbox is in drive until I flick the switch. I also have an autowatch alarm/imobilizer Plus a labrador that barks if he hears anything outside at night (he's surprisingly sensitive). And I'm lucky to live in a good area in a small village. My main security device at the moment though is I have no wheels, engine, diff, hubs... Edited July 12, 2020 by bluecoupe46 (see edit history) Link to comment Share on other sites More sharing options...
Mo Reviews Posted July 13, 2020 Share Posted July 13, 2020 Clifford alarms are as good as you're going to get on a Supra really... something like a Concept 650, tried and tested for over a decade. Contact Shervin, he's a authorised Clifford dealer and has supplied and fitted the alarms on all my Supras. Top chap. Link to comment Share on other sites More sharing options...
safcdixon Posted July 13, 2020 Share Posted July 13, 2020 The missus has those disk locks on her two fords One old, one new, they have a good reputation and are a viewable deterrent from outside the car theyre about £120 iirc, or how about a removable steering wheel instead, im not a fan of how they sit closer to the driver but others seem to cope with it just fine Link to comment Share on other sites More sharing options...
Style Posted July 13, 2020 Share Posted July 13, 2020 At least it's not an RS Turbo Didn't matter what you did with those things in Dundee 15 years ago, they'd get bumped without fail! Link to comment Share on other sites More sharing options...
Johnm400 Posted July 13, 2020 Share Posted July 13, 2020 At least it's not an RS Turbo Didn't matter what you did with those things in Dundee 15 years ago, they'd get bumped without fail! LOL, my cousin had 3 in the 90s and every one got robbed. Link to comment Share on other sites More sharing options...
Johnm400 Posted July 13, 2020 Share Posted July 13, 2020 Hi john, I think I will do that but I might actually put the switch in the boot close to where the pump is. It wouldn’t be the first place someone would look as it’s not exactly a convenient place. It’s just for when I leave the car overnight. Not for if I just go into a shop or a restaurant. Only problem with putting it in the boot is that somebody could watch you going to the boot every night before you go into the house. Its up to you but id put the switch somewhere you can reach it whilst in the car so you can flick it over discreetly without anybody knowing. Link to comment Share on other sites More sharing options...
Johnm400 Posted July 13, 2020 Share Posted July 13, 2020 I also have an autowatch alarm/imobilizer Ive got an Autowatch fitted. It always makes me laugh when you try to open then lock the car too fast, it sounds like its in agony! Link to comment Share on other sites More sharing options...
Marcus GTE Posted July 14, 2020 Share Posted July 14, 2020 Clifford alarms are as good as you're going to get on a Supra really... something like a Concept 650, tried and tested for over a decade. Contact Shervin, he's a authorised Clifford dealer and has supplied and fitted the alarms on all my Supras. Top chap. I’ve looked at pictures of that alarm kit and was wondering where the part with the small antenna gets installed? Kinda looks like the old mobile phone steals you used to have to pull out. Link to comment Share on other sites More sharing options...
wile e coyote Posted July 15, 2020 Share Posted July 15, 2020 Tbh I can’t remember ever hearing of anybody’s supra being stolen Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 15, 2020 Share Posted July 15, 2020 Just leave a note on the window sayings it an NA auto. No one will steal it then Link to comment Share on other sites More sharing options...
The Raven Posted July 15, 2020 Share Posted July 15, 2020 Just hope no one works out how much the ashtray is worth Link to comment Share on other sites More sharing options...
Scooter Posted July 15, 2020 Share Posted July 15, 2020 (edited) Tbh I can’t remember ever hearing of anybody’s supra being stolen I can only remember one many moons ago..... edit Edited July 15, 2020 by Scooter (see edit history) Link to comment Share on other sites More sharing options...
jamesmark Posted July 15, 2020 Share Posted July 15, 2020 At least it's not an RS Turbo Didn't matter what you did with those things in Dundee 15 years ago, they'd get bumped without fail! As with all cars, extra security is as the title of this thread says, only a 'deterrent'. If a thief wants your car they will get it regardless of what you fit or disable in full view of any CCTV. Will just take them longer is all. Link to comment Share on other sites More sharing options...
David P Posted July 15, 2020 Share Posted July 15, 2020 Re-purpose an airbag! Link to comment Share on other sites More sharing options...
Mo Reviews Posted July 15, 2020 Share Posted July 15, 2020 I’ve looked at pictures of that alarm kit and was wondering where the part with the small antenna gets installed? Kinda looks like the old mobile phone steals you used to have to pull out. You can hide it out of sight; behind the dash, in the centre consol, etc. Works like a charm... Link to comment Share on other sites More sharing options...
Mo Reviews Posted July 15, 2020 Share Posted July 15, 2020 Re-purpose an airbag! That's awesome!! Link to comment Share on other sites More sharing options...
