Mike2JZ Posted June 28, 2020 Share Posted June 28, 2020 Hi, Just upgraded to new wheels so have old set available. Specs Fronts: Japan Racing JR10 18, 8.5'' +25 Federal RSR 595 Semi Slicks, 245/35/18 Rears: Japan Racing JR10 18, 10.5'' +12 Federal RSR 595 Semi Slicks 285/30/18 Wheels are "Machined Silver" finish. They are about 3 years old, and have some curb rash and also some clear coat peeling/corrosion. Aesthetics aside, the wheels are straight & come with center caps. Tyres are a year old, only done 1000 miles with 5mm tread left on all 4, super sticky and put down 700hp with no issues. Forum Price: £500 for wheels and tyres. Collection from SRD or can quote for postage. Link to comment Share on other sites More sharing options...
shaz2010 Posted June 29, 2020 Share Posted June 29, 2020 Hi mate I presume these don’t fit under normal arch and what about Uk spec bigger brakes Link to comment Share on other sites More sharing options...
erachter Posted June 29, 2020 Share Posted June 29, 2020 Hi mate I presume these don’t fit under normal arch and what about Uk spec bigger brakes not sure about these, but I had JR10 8.5 ET40 in the front and they need a 20mm spacer to fit over UK big brakes Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 29, 2020 Author Share Posted June 29, 2020 Fronts are flush fit for OEM arches, fits over big brakes. Rear wheels will poke a bit using a stock arch, Link to comment Share on other sites More sharing options...
shaz2010 Posted June 29, 2020 Share Posted June 29, 2020 You got pics on the car mike cheers Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 29, 2020 Author Share Posted June 29, 2020 no i havent Link to comment Share on other sites More sharing options...
auzzam Posted June 30, 2020 Share Posted June 30, 2020 Fronts are flush fit for OEM arches, fits over big brakes. Rear wheels will poke a bit using a stock arch, Would it be any better if the arches were rolled? Did it rub at all Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 30, 2020 Author Share Posted June 30, 2020 I am using ridox arches so cant comment on fitment for stock arch. Can recomend using willtheyfit.com to calculate how much further they will stick out compared to current setup, then go measure on your own car Link to comment Share on other sites More sharing options...
Stitches Posted July 1, 2020 Share Posted July 1, 2020 (edited) Pm sent Edited July 1, 2020 by Stitches (see edit history) Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 1, 2020 Author Share Posted July 1, 2020 Sold Link to comment Share on other sites More sharing options...
