1995 Toyota Supra TT - RZ-S - Pre face - Auto - Black - 55k miles
Lewmc93
Make: Toyota
Model: RZ-S twin turbo - Auto
Year: 1995
Colour: Black
Facelift: No
Mileage: 55,200
MOT remaining: 01/05/2021
Service history: Japanese Service book and service history. UK receipts and service records
Car's location: Liverpool
Modifications:
Laser line thatcham 1 alarm and immobiliser, 4 keys.
Full bpu supplied and fitted by whifbitz approx 410bhp
Whifbitz 1st decat
Whifbitz 1 bar restrictor ring
Hks 3 inch front pipe (2nd decat)
Hks silent hi power exhaust
Hks fuel cut defender
Hks super power flow induction kit
Whifbitz 4 inch thick front mount intercooler
NGK iridium spark plugs set
Walbro 255LPH updated fuel pump
Greddy profec boost controller
Tein s tech lowering springs
19 inch wheel mania vortex r wheels 8.5 front, 9.5 rear just refurbished in satin black
Nearly new uniroyal rainsport 1 tyres
UK brakes
Brand new Toyota discs
Brand new Chris Wilson fast road pads
Goodridge braided brake line kit
Tinted front and side indicators
Pioneer MVH-S420BT single DIN bluetooth radio
4 x Pioneer TS-R1750S Speakers
Dodo deadmat DUO covered doors and cabin.
Interior stripped and cleaned under.
SRD Speaker brackets
SRD AC delete black Billet support - No AC
New Windscreen wipers
Upgraded washer jets to spray type
Good bits:
Mechanically it runs sweet as a nut, well looked after by previous owner and myself in the short time owning it. I stripped the interior and boot back to shell and cleaned it up, while also tidying up the wiring and apply sound deadening in the cabin and doors.
Was garaged by the previous owner so is a solid frame and minimal to no rust.
Just had oil and oil filter change using Fuchs titan oil, k&n oil filter, coolant change and flush. Motul brake fluid
New Aux Belt when fitting AC delete bracket
Bad bits:
Would benefit from a respray as cosmetic marks on body and a previously touched up swipe mark on the rear driver side arch. Few of the general chips and marks could be touched up with the touch up rattle can but honestly my skills dont reach that far in regards to painting etc. Although i would add this isn't a garage queen and is a daily so its being used like it was made for
Spares/bits
First factory cat
Original speakers and pods
Interior clips and bits
Aux belt
Misc
Throwing this up for sale due to seeing a house at auction next month, and its peaked my interest a fair bit, so diving in head first as i do otherwise i wouldn't be selling this as i searched for over a year for a good condition black auto TT
priced according to what i would make me let it go.
SOLD PRICE £19500
Edited by Lewmc93
SOLD (see edit history)
Looks like there could be a problem with the ABS warning bulb on the right panel display. With the market price drive to stock I suppose its debatable whether no AC is a bad bit, that probably depends on how far the delete went as to whether it could be reinstalled and reinstated at reasonable cost or not.
There's nothing wrong with the abs light ? It comes on and goes off as normal.
I did the AC delete, the radiator was leaking at the bottom, so removed it up to the firewall, still have all the pipes etc just no radiator as it was leaking. So few hours and whatever a new radiator costs+recharge.
The ABS light does go off fairly quickly so you would need to be quick to catch it on camera but its always worth checking that as it is a common quick fix to wheel speed sensor problems, to delete the ABS light.
I always wonder about AC being a simple fix as I once paid a garage over £1,000 many years ago to replace the condenser and recharge. Probably not unreasonable seeing Toyota charged £600 for the part at the time, today you can buy the same Denso part for a little over £100. So the parts would be under £200 for the condenser, a new drier and the recharge R134a. I don't have a feel for how much an AC delete devalues a car but I'd suspect its a lot more than it'd cost you in parts to undelete. Not likely to worry anyone if the lack of AC was reflected in the price, though £21k is nudging up there with the very best.
Updated google drive with picture of ABS light working to reassure anyone , that it does indeed work.
When i bought the car the AC worked but over 3 days after a recharge it would empty. After getting a dye test and pressure test all pipes and compressor where verified okay. The radiator was knackered at the lower corner. I've put a picture of the part in the google drive for people to see the dead radiator. That is the only thing that would need buying new if they needed AC. I still have everything else for it to work in the shed boxed up.
Again i'm not going to sugar coat my price. Its what i want/need for it for any meaningful bid on this auction property. Although any serious enquiries will have negotiating in as always,its flexible to a degree.
