Radiator
Boyne
I ran stock rad in my BPU UK spec and never had a problem, even with a stupid
R spec intercooler stuck in front of it
Yes going back stock getting one of keron, shiny aftermarket unreal poor quality, sump plug broke of only in the car a month, opened twice
I guess its made from a poor grade of aluminium alloy that's just not up to the job
What make was this ?
I've got a Mishimoto on my car.
I was assured they were the same quality and as there was few week wait for the mishito I went for whibitz brand one. Live and learn plenty of experience guys on here should listen to them, stock it is.
I have same problem here with a new radiator i bought from whibitz, with a leaking bore in the radiator... they said too they never have had any problems with their radiators, but there is a first time to everything... so looking forward to see what solutions i can get with them..
Edited by jza800 (see edit history)
I bought in a new radiator as a spare last year seeing my car is still running on its original. Got it via TCB and there is no longer an OEM option but there are radiators that look similar (including an expensive Blue Print option) that are listed for the Supra. You can get an auto rad which will fit and work in both an auto or MT car or for and extra £60 you could get a manual rad which is the same minus the oil cooler element. So, I bought an auto rad and if people want you can always run your PAS fluid through it or just leave it unused.
I wrote a thread last year on radiators that detailed all the lookalike options.
As far as I’m aware you can’t get a OEM manual radiator anymore.
I hope your wrong I know toyota dont sell them, but what is keron then selling is this a genuine stock radiator, I dont want to get stung twice, be nearly 500 pound up the swanny for radiators.
Use the auto rad if its available and don't use the autobox cooler on it, just
blank it off if your cars manual
So lads is the auto rad available from toyota but the manual is not is this correct?
Hi Nigel
Based on a 1996 UK EUR AET RHD 2JZGTE MTM 6F (JZA80R-AJFVZW)
Part number showing is 16400-46310, its discontinued
I am running the Koyo rad , since 2013 , no issues ; just make sure you get it from an authorised dealer , I am sure copies are floating around on ebay
UK Auto rad 16400-46320 , is also out of production
Hi Dunk, Why is the auto rad the best choice, is it because it is less expensive?
I've no idea on the price for either OE auto or manual radiators but if you have a manual car
you can use the auto radiator if the manual is no longer available.
If both are unavailable then your into the aftermarket world so need to be careful and go from
others experiences
I've just done that on my BMW as my trusted local garage recommended i fit a Nissens radiator
which is 1/4 of the price of OE from BMW
Hi Nigel
Thanks carlo and lads for the help I'm on to keron he assures me his rad is stock
The OEM radiators are far superior quality to most of the cheap rubbish that’s out there. My radiator lasted 22 years before it needed replacing.
I got 25yrs similar to you, however all the stock radiators are discontinued, keron assures me his rad is made from a new original sent away to be duplicated. So will update that's in transit, And yes cheap rubbish is putting it mildly.
