Toyota red coolant pre mixed
Boyne
I think if you add deionised water you'll be fine, it's what I add to the concentrate.
Coolant concentration is a balance, water is better on it's own for cooling efficiency but obviously corrosion is an issue as is freezing in the winter. In siberia you'd run a higher concentrate of coolant/antifreeze and in Arizona you could run lower, but as is will be a happy medium especially in our temperate climate.
As a matter of interest how many liters is required for a complete change?
See this thread here:
https://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
You'll need a couple of the 5L bottles.
If you're doing a complete change, i'd run some deionised water through the system first if the coolant hasn't been changed in a while, mine hadn't for what appeared to be at least a decade so I had to flush it three times!
Edited by m12aak
Added extra info (see edit history)
I have 5liters red coolant in rest battery deionised water just temporary in new alloy rad, car is a lot cooler, then I can remember, have the 10liters now so I will drain and fill it with just the coolant so.
