How to reprogram alarm fob
MrRalphMan
I've had the battery off the car for a couple of weeks and when I tried to move it today I couldn't turn the alarm off, so I assume the fob has become unsynced from the alarm.
I've found a few methods on here too reset it, but none have worked so far. This is the standard alarm, with the square fob, so do you know the correct methods for that type?
Fanks
Paul
Thanks for the reply mate, yes I've the castle key, but looks like the sounder under the bonnet has been removed already, so it only sounds when the battery is connected.
Tried a few things, like pressing the button or buttons for 15 seconds or so.
Going to try the 'removing the dome fuse' method, but might try replacing the fob battery first.
At least I can drive it with the alarm going of, to move it, as it's got a separate Clifford immobiliser.
Paul
