Picoto Posted June 13, 2020 Share Posted June 13, 2020 Who else here has used the 7mgte cps on an NA-T. Need some info please. Car sounds like it wants to start just won’t. Sounds like timing but we have checked and it looks bang on. Quote Link to comment Share on other sites More sharing options...
Gpro Posted June 15, 2020 Share Posted June 15, 2020 check your spark plugs to see if they are wet with fuel, to rule out fueling issues. Can use a spark tester to see if you are getting spark Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted June 15, 2020 Share Posted June 15, 2020 What ECU are you running?? I had this on a stock GTE block with the Syvecs on it and the Cam sensor had gone. Could see it in the ECU logs that it was getting zero signal. But standard process, are you getting fuel, are you getting spark? Quote Link to comment Share on other sites More sharing options...
