Jellybean Posted June 12, 2020 Share Posted June 12, 2020 (edited) Car: Eng: 2JZ-GTE MTM 6 Speed Location: Leicester UK Condition: Like New Reason for Sale: Going Single JZA80 Supra TT intake/throttle with the TRAC/ETCS Butterfly Valve Delete Kit -- 249 GBP TRAC^Butterfly^Valve Delete Kit is similar (but IMO better) to the long-discontinued HKS TRAC traction control delete kit, and provides a clean, bolt-on manner in which to permanently remove the extra throttle plate found in stock throttle bodies, along with the accompanying position sensor and actuator motor. Advantages are a less cluttered engine bay, and less intake restriction in the throttle body, with the extra butterfly valve removed. HKS claimed an engine horsepower increase, but I have no idea if and to what extent that is true. The kits consist of A Pair of precision CNCed 6061 Aluminum Plugs. 2 Viton O-rings. A Raw 6061 Cover Plate for removal of the traction motor. It has provision for a 1/8 NTP threaded port I ran the car at BPU with 264 cams , EGT's all good , made 424hp @ 1.3 Bar and 431.9 ftlb Torque, Rev limit set to 7100 from Stock 6800rpm on 95 octane fuel Less Edited June 12, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2020 Author Share Posted June 12, 2020 (edited) JDM JZA80 Supra TT turbo intake pipes & Heat Shield -- 99 Gbp As New OE Link Pipes Edited June 12, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2020 Author Share Posted June 12, 2020 (edited) JZA80 JDM TT OE Turbos -- 199 Gbp No shaft play, rear turbo needs new seal Video Edited June 12, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2020 Author Share Posted June 12, 2020 (edited) New in box,never used: Fuel/oil lines and fittings -- 250 gbp Cost GBP 355.83 from Torques UK Reason for sale -- Going with different Color combo Lines (uncut/ touched) AN -10 AN10 ( -10 JIC ) Nylon Braided Stealth Black Hose 6m (Pro Lite Type) AN -6 (AN6) Black Nylon Braided Oil / Fuel Hose 6.0m Fittings AN -10 (AN10 JIC -10) 90 Degree ULTRAFLOW Swivel Seal Hose Fitting In BLACK AN -10 (10AN AN10) STRAIGHT To 1/2" BSP Female Swivel Seal Hose Fitting Black AN -6 (6AN) Banjo Adapter To M12x1.25 Stainless Steel Banjo Bolt Assembly BLACK (Fuel return) AN-6 (AN6) STRAIGHT FastFlow Stealth Black Hose Fitting AN -6 (AN6 JIC -6 AN 06) 90 Degree ULTRAFLOW Swivel Seal Hose Fitting In BLACK Fuel Filter Bosch 0450905021 AN-6 (JIC -06) High Performance Fuel Filter 8 Micron In Black Edited June 12, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Danhook97 Posted June 12, 2020 Share Posted June 12, 2020 Will you be selling full clutch assembly? Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2020 Author Share Posted June 12, 2020 (edited) Supra JZA80 TT Fuel Pulsation Damper Removal -- 44 Gbp Edited June 12, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted June 12, 2020 Author Share Posted June 12, 2020 Will you be selling full clutch assembly? I am just selling an OsGiken Clutch , and a working Clutch master cylinder but the Clutch master cylinder is till on the car http://www.mkivsupra.net/vbb/showthread.php?358442-OsGiken-Clutch-575-ft-lb-(600-650-HP)-(TY031-BQ6) Link to comment Share on other sites More sharing options...
Boyne Posted June 12, 2020 Share Posted June 12, 2020 What turbo carlo you going for - - - Updated - - - What turbo carlo you going for Link to comment Share on other sites More sharing options...
Jellybean Posted June 14, 2020 Author Share Posted June 14, 2020 What turbo carlo you going for - - - Updated - - - What turbo carlo you going for6466 gen2 Link to comment Share on other sites More sharing options...
Boyne Posted June 14, 2020 Share Posted June 14, 2020 6466 gen2 /QUOTE] When you expecting it back you have to take me out in it Link to comment Share on other sites More sharing options...
Jellybean Posted June 14, 2020 Author Share Posted June 14, 2020 Provisionally Sold OE Turbos TT turbo intake pipes & Heat Shield OE Intake Link to comment Share on other sites More sharing options...
Jellybean Posted June 14, 2020 Author Share Posted June 14, 2020 When you expecting it back you have to take me out in it Will be a while , no rush to get it back , earliest will be getting into the winter , so said to hold out ,probably till the new year , put a stroker 3.4 in her, all internals will be super finished Most likely have it back during the winter Link to comment Share on other sites More sharing options...
