OsGiken Clutch 575 ft-lb (600-650 HP) (TY031-BQ6)
Jellybean
  • 2 weeks later...
  jellybean said:
car: Eng: 2jz-gte mtm 6 speed
mileage: 1000 km or less
condition: Like new
reason for sale: More power
price: 699 incl shipping within uk mainland
**invoice attached is ex-customs and vat
**everything you need to install**
clutch:
Brand: Os giken
product: Street master clutch kit - twin-metal hard
part num: Gt2cd (ty031-bq6)
rated to approx 575 ft-lb (600-650 hp)
additional parts supplied
- movement kit included.
- sleeve release bearing included.
- os giken flywheel bolts (arp)
installation,
she installs and uses all oem components( i.e. Oem slave cylinder); first impressions on startup is noise, none existent on idle , cruising and wot . The pedal has a really nice feel, sprung enough to allow easy modulation (slippage) but light enough to not impede drivability , if i was to put a number versus stock 10% heavier pedal.
The biting point would be on par with oem , slow speeds all smooth , not grabby; just a pity it will not suit my power levels
to date i would highly recommend this clutch , car is a pleasure to drive and in comparison to an oem clutch the feel on the pedal with this clutch in my opinion results in a nicer drive.
**clear up any confusion**
the clutch is marketed as
**street master** in jdm (japan) ,
https://www.osgiken.co.jp/pro_clutch/clutch/gt2cd.html?fbclid=iwar1wmk4dhteeyyludylwdyyqreswvieqi3gwlcfcie5qwicgfzfoyvxtoec
**grand touring** in the us market (usdm)
https://osgikenusa.com/collections/clutch1/products/ty031-bq6?fbclid=iwar2ot5ykp2nmucfs2xk4ajbmorseprbzvmvyfcebimrkgc0qjot8fhunwso
**both have the same part number gt2cd (ty031-bq6)
os giken grand touring twin plate clutch for an v160 6-speed transmission on a 2jz engine, type gt2cd. This model clutch uses os giken's special "floating pressure system" technology to make this a quiet, rattle-free twin plate clutch! This version also has a firm spring so pedal pressure is a little more then stock, but the power handling is rated at 600-650hp. This is a great street car clutch, with enough power handling for modified single turbo engines. This twin plate clutch/flywheel kit includes the movement alteration kit that changes it from a pull to a push type clutch.
https://www.driftmotion.com/ty031-bq6-p/dm2563.htm?fbclid=iwar2ot5ykp2nmucfs2xk4ajbmorseprbzvmvyfcebimrkgc0qjot8fhunwso less
https://jza80.mkivsupra.net/imports/2020/06/4.png
https://jza80.mkivsupra.net/imports/2019/08/232.jpg
https://jza80.mkivsupra.net/imports/2020/06/3.png
https://jza80.mkivsupra.net/imports/2019/10/174.jpg
https://jza80.mkivsupra.net/imports/2019/10/175.jpg
https://jza80.mkivsupra.net/imports/2019/10/176.jpg
https://jza80.mkivsupra.net/imports/2020/06/91.jpg
https://jza80.mkivsupra.net/imports/2020/02/140.jpg
pm
