Jellybean Posted June 12, 2020 Share Posted June 12, 2020 (edited) Sold Edited June 27, 2020 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
leon_83 Posted June 25, 2020 Share Posted June 25, 2020 car: Eng: 2jz-gte mtm 6 speed mileage: 1000 km or less location: Leicester uk condition: Like new reason for sale: More power price: 699 incl shipping within uk mainland **invoice attached is ex-customs and vat ************************************** **everything you need to install** ************************************** clutch: Brand: Os giken product: Street master clutch kit - twin-metal hard part num: Gt2cd (ty031-bq6) rated to approx 575 ft-lb (600-650 hp) additional parts supplied - movement kit included. - sleeve release bearing included. - os giken flywheel bolts (arp) ************* installation, ************* she installs and uses all oem components( i.e. Oem slave cylinder); first impressions on startup is noise, none existent on idle , cruising and wot . The pedal has a really nice feel, sprung enough to allow easy modulation (slippage) but light enough to not impede drivability , if i was to put a number versus stock 10% heavier pedal. The biting point would be on par with oem , slow speeds all smooth , not grabby; just a pity it will not suit my power levels to date i would highly recommend this clutch , car is a pleasure to drive and in comparison to an oem clutch the feel on the pedal with this clutch in my opinion results in a nicer drive. ******************************* **clear up any confusion** ******************************* the clutch is marketed as **street master** in jdm (japan) , https://www.osgiken.co.jp/pro_clutch/clutch/gt2cd.html?fbclid=iwar1wmk4dhteeyyludylwdyyqreswvieqi3gwlcfcie5qwicgfzfoyvxtoec **grand touring** in the us market (usdm) https://osgikenusa.com/collections/clutch1/products/ty031-bq6?fbclid=iwar2ot5ykp2nmucfs2xk4ajbmorseprbzvmvyfcebimrkgc0qjot8fhunwso **both have the same part number gt2cd (ty031-bq6) os giken grand touring twin plate clutch for an v160 6-speed transmission on a 2jz engine, type gt2cd. This model clutch uses os giken's special "floating pressure system" technology to make this a quiet, rattle-free twin plate clutch! This version also has a firm spring so pedal pressure is a little more then stock, but the power handling is rated at 600-650hp. This is a great street car clutch, with enough power handling for modified single turbo engines. This twin plate clutch/flywheel kit includes the movement alteration kit that changes it from a pull to a push type clutch. https://www.driftmotion.com/ty031-bq6-p/dm2563.htm?fbclid=iwar2ot5ykp2nmucfs2xk4ajbmorseprbzvmvyfcebimrkgc0qjot8fhunwso less https://jza80.mkivsupra.net/imports/2020/06/4.png https://jza80.mkivsupra.net/imports/2019/08/232.jpg https://jza80.mkivsupra.net/imports/2020/06/3.png https://jza80.mkivsupra.net/imports/2019/10/174.jpg https://jza80.mkivsupra.net/imports/2019/10/175.jpg https://jza80.mkivsupra.net/imports/2019/10/176.jpg https://jza80.mkivsupra.net/imports/2020/06/91.jpg https://jza80.mkivsupra.net/imports/2020/02/140.jpg pm Link to comment Share on other sites More sharing options...
