Manual conversion
Danhook97
Amayama shows these, not sure which bits you exactly need -
https://www.amayama.com/en/part/toyota/5510714120 - For the bracket
Pedal is discontinued but they list this which may work (please confirm yourself) - https://www.amayama.com/en/part/toyota/3130114120
Looks like you it doesnt come with bushes, springs, bolts etc though.
Toyodiy only shows these parts used on the Supra though.
I assume you have tried Keron?
eBay search brings up one is Austrailia (again please check fitment for yourself)
I believe someone found that the IS200 clutch pedal may fit? Worth checking on that though
/QUOTE]
Thankyou, not sure if im doing something wrong, but when i use the search bar it doesnt seem to display the subjects im after? Any ideas why? Also did shawn get in touch about the clutch master cylinder?
