Anyway of checking if map sensor if faulty
sidewaysdan
Yes it will I thought you was on about a stock sensor . So I take it your after market ECU. This will show the map sensor pressure what you could do is get a boost gauge and see if they match in your ECU software. Failing that you might find the sensor data sheet which should say it's output voltages for you to check .
