Auto Flexplate, alternator, new TT headgasket
bluecoupe46
[ATTACH=CONFIG]236317[/ATTACH][ATTACH=CONFIG]236319[/ATTACH] Don’t know if that’s ok and any use to you buddy removed auto box when went manual conversion
Hi mate,
I've just purchased one from another forum member.
Is this from a GE or a GTE?
Out of interest how much are you after?
The adapter kit I'm going for gives both the ge and gte flexplate part numbers, but only mentions the gte engine. The flexplates are slightly different, so can't confirm which one will fit, or if they both will.
From a NA auto buddy I basically got all my auto parts from when I changed to manual turbo
Flexplate £10 Auto box £30 and shifter without handle £10
Then what ever postage costs
Hi mate,
No worries, thanks very much. However I've already purchased an NA flexplate, so just wanted to potentially get a TT flexplate incase the NA doesn't actually fit the PMC motorsport adapter kit/flywheel.
Yes new genuine toyota gasket. £120 delivered
OK,
Give me a few days to work out the best route (I.e. Whether it's better for me to get a full engine gasket set, as I'll also need a front and rear main seal) or buy those separately.
Cheers
