How to change auto gear lever
cbowditch
I'm trying to change the leather cover on the auto gear lever. I did a forum search and found reference to hidden screws but no further details. I found the hidden screws, popped out the 2 buttons and took cover off plastic lever. However the small button is connected to 2 wires and I can't see how to disconnect the button so it can pass through the lever. See picture, can anyone advise how to do this?
You dont have to cut the wires.
If you trace back the cables it goes to a blue plug to the front left side of the shifter. You can use a de-pin tool to depin it. However it usually is easier to just cut it.
If I remember rightly, you undo the screws on the selector plate (which has the D, P, N etc. on it), then lift it up which gives you access underneath it and to the connectors for those wires. It saves you having to cut and solder but is more fiddly.
Thanks guys. I don't have a de-pin tool, so looks like I will either cut the wires or leave the old tatty shifter cover on. I managed to lose the big button as well. It pinged off somewhere in the car/garage and I can't find it anywhere. Does anyone know where I can buy a new one?
