2JZ-GTE Race spec head (non vvti)
ShawnPreece
For sale is my race spec 2JZ-GTE non vvti head
This was in my Supra running 1031bhp on pump fuel and full spec of head is:
Ported and polished
GSC Beehive valve spring kit
GSC intake valves
GSC exhaust valves
GSC Viton valve stem seals
Shimless buckets
GSC stage 2 274 cams
HKS adjustable cam pulleys
It does have quite abit of wear detailed below...
The valves and guides have had some wear.
The valve seats also have wear but could be reused.
Cams could be reused but ideally need changing from abnormal wear.
Wear to cam lobes and buckets.
There is visible wear to valve stems, they vary in size but generally have 0.02mm of uneven wear.
The port work is all still fine.
Reason for sale is to go for a vvti head to compliment my setup rather than re-using this head.
Look through all the pictures as I have included as many as possible showing the wear, the head is currently at SRD and I can ask for any more photos on request and I will try to answer any questions I can but I have been as honest as possible about the condition of it.
£1900 collected (from SRD) or I’m sure I could arrange delivery with Lee for a little extra
Edited by ShawnPreece (see edit history)
