L337 Posted December 3, 2020 Share Posted December 3, 2020 Well Amayama cancelled the order, but Toyota came through with a 14020 part for £200. Fitted fine Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted December 3, 2020 Share Posted December 3, 2020 Good to hear you managed to get one Quote Link to comment Share on other sites More sharing options...
Noz Posted December 4, 2020 Share Posted December 4, 2020 Surely we should be trying to come up collectively with a retro fit version for this type of setup for OEM ECUs. I stand by my previous comment if we could determine the signal output we could communicate most sensors to the same required wave form. I'm certain the OEM ecu uses a simple type of wave. Quote Link to comment Share on other sites More sharing options...
Halfwalker Posted June 4, 2021 Share Posted June 4, 2021 On 8/27/2020 at 2:47 PM, Jellybean said: Considering majority of owners run an aftermarket ECU and the OE ECU is starting to fail with age Not consider running Digital Hall Effect Sensor, CP Racing was making a CNC Supra MK4 Wheel Speed Bracket for Digital Hall Effect Sensor These CNC brackets are meant to house a Digital Hall sensor to give a cleaner “square” wave digital signal to your ECU. The OEM ABS sensors on the MKIV are a magnetic sensor which tend to drop out and give incorrect wheel speed information to your ECU. These changes can cause a misread in traction control, gear position, rpm limit, and boost control depending on your tune. With a Digital Hall sensor you will always have a crisp clean reading even at the lowest speed to give your ECU the most accurate information at all times. No more ground or drive speed drop outs! Does anyone know just what sensors these brackets are designed to accept ? I'm assuming it's the Haltech ones ? http://www.wotm.com/haltech/haltech-ecu-inputs-hall-effect-sensor/g-64682.aspx Quote Link to comment Share on other sites More sharing options...
Ric Posted June 6, 2021 Share Posted June 6, 2021 A friend of mine has a source for ABS sensors they are tried and tested around £40 each i think. He might actually be on the forum. Andy Ventress 1 Quote Link to comment Share on other sites More sharing options...
Burna Posted June 7, 2021 Share Posted June 7, 2021 10 hours ago, Ric said: A friend of mine has a source for ABS sensors they are tried and tested around £40 each i think. He might actually be on the forum. Andy Ventress Yeah seen Andy's on facebook a while a go, £65 each, or 2 for £120. They look a great solution. All you need is your original bracket he says, and they are plug'n'play! Quote Link to comment Share on other sites More sharing options...
