NA Head Gasket Part Number
Eightdip
Hi guys,
Does anyone know the part number for a NA 1995 J Spec Supra OEM Head Gasket? I've seen part numbers ranging from 11115-46040 all the way to 11115-46045. Anyone know the difference between the 6 part numbers?
Also does anyone know a good place to get one? Not looking for a full gasket kit like on Whifbitz, just need the Gasket itself. I've found a couple on ebay but not sure of the brands, anyone used ICP or Victor Reinz before?
I also need bolts, any recommendations of place to get good OEM spec bolts?
Toyota or TCP for the gasket and the bolts, quality guaranteed which is what you want from an HG.
Re part numbers, Toyota change part numbers for fun so it could be compatible but with a material spec change, or different colour or something
Can you not buy the Whifbitz head gasket kit and sell on the other parts that you don't need/ want that come with the kit? Other than that I'd say go with Toyota, just ask for more money off if they can, if they're anything like my local dealership they will knock a bit more off.
For the head bolts perhaps look into ARP head studs, not OEM but good quality and certainly cheaper than Toyota UK prices. I'd normally say buy them from amayama as they are currently £8 per bolt from Japan, but they would take an age to arrive and at present they are only using DHL for posting which is expensive!
I doing a NA-T conversion and don’t need the Head gasket but need the rest of the engine gaskets if you do decide to get a complete engine set PM me a price through if want to consider Need crank seals and inlet gaskets and that you see
cheers for the responses guys!
checking with Whifbitz if they sell the head gasket separately.
Dan - I'll give you a shout if I end up getting the kit
Scooter - I'll need it in the next couple of weeks so can't really rely on international shipping, thanks for finding that though!
