Identifying rod bearing number
Dan8
Hi
In process of doing my full NA-T build with completely rebuilt engine
According to the pdf manual there are several different sizes of standard sizes rod bearings 3C47C2F3-FE44-410C-8758-0814607D6C78.png I will be removing the crank and replacing everything there to anyways meaning I can use my measuring equipment and plastigauge meaning I can just find out by measuring and checking but is this rod bearing a standard OEM number 5 bearing just by looking at the reference number on it ACA3A51D-60D7-4A96-A357-9927201A7874.jpeg
And if I use ACL or uprated bearings do there standard bearing offer this or is it one standard ACL bearing comes in one set tolerance
Thanks for any help and info
Edited by Dan8 (see edit history)
